zmMemVerify always false in script (see FAQ)
digitalm
Post by digitalm »
Hi All,
Just upgraded to ZoneMinder 1.25 and my perl script which checks if monitors have alarmed no longer works.
using the example from the FAQ
#!/usr/bin/perl -w
use strict;
use ZoneMinder;
$| = 1;
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)";
my @monitors;
    push( @monitors, $monitor );
while( 1 )
        next if ( !zmMemVerify( $monitor ) );
        print( "Checking Monitor ".$monitor->{Name}."\n" );
            # Do your stuff here
    sleep( 1 );
First issue is zmDbgInit no longer exists, I commented this out and all seems to be ok.
Second issue is zmMemVerify is always false so it never actually checks if its alarms, if I comment that line out I get the following error :
Use of uninitialized value $state in numeric eq (==) at /usr/share/perl5/ZoneMinder/Memory.pm line 497.
Use of uninitialized value $last_event_id in numeric ne (!=) at /usr/share/perl5/ZoneMinder/Memory.pm line 501.
Use of uninitialized value $last_event in numeric ne (!=) at /usr/share/perl5/ZoneMinder/Memory.pm line 501.
Someone else asked this recently and didn't get an answer - http://www.zoneminder.com/forums/viewto ... mMemVerify
Any ideas?
thanks
Toby
digitalm
Re: zmMemVerify always false in script (see FAQ)
Post by digitalm »
Just noticed in syslog there is
Jan  9 17:17:23 video-server zm_watch[8723]: ERR [Shared data size conflict in shared_data for monitor FrontDrive, expected 328, got 316]
so i assume this is the cause?
digitalm
Post by digitalm »
Ok fixed it myself, first thing to fix Shared data size conflict I did the fix said here
http://lachlanmiskin.com/blog/2012/06/2 ... r-monitor/
then in the code I changed
if ( zmMemVerify( $monitor ) && zmMemRead( $monitor, "shared_data:valid" ) )
blah..
