Can't view stream when authentication is enabled
mmulqu
Post by mmulqu »
I just started using zoneminder last night. It's a really great package. This morning, I decided it would be a good idea to enable authentication since the stream is available on a wireless network. Unfortunately, I've found that I can't view the stream or events from the webpage when authentication is enabled. The log shows the following error while authentication is enabled:
2013-01-16 17:14:23.763620 zms 1676 ERR Unable to authenticate user zms.cpp 221
I've searched for this problem and not found a solution. I also, reinstalled the OS, Fedora 17 64-bit, on the machine and repeated the installation steps found at http://www.zoneminder.com/wiki/index.ph ... #Fedora_17 but the problem persists.
Any help getting this fixed would be appreciated. If you need any additional information from me, please just ask.
Thanks,
Matt
