1.25 zm RTSP problem white public IP
hk_niko
Post by hk_niko »
Hi, I have a 1.25 zm where I entered the rtsp streams.
Some of the streams passing through radio bridge ubiquiti 5ghz and I have no problem with the display (both on vlc that zm) streams. While I have other streams rtsp that I read on a public IP address, but in this case I have problems opening the stream, with vlc I view the images after about 15 seconds with no problem, while on zm I can not open it and I see only the monitor blacks ... how can I solve this problem?
NB: I have set HTTP_TIMEOUT = 30000 to try but it did not work
