event replay?
lobzik
event replay?
Post by lobzik »
I have strange problems with replaying events. I have 5 monitors in Modect mode, ZM 1.25.0 running on Fedora 14.
The main thing is when I'm using Gapless replay mode, it plays only events from one monitor. E.g., I click on Day's events and I can see all events from all monitors in the list. Then I click on any of them, e.g. from Monitor-2, and set Gapless mode; it starts to play events, but only from Monitor-2, however there was more events from Monitor-1, Monitor-3 in the list! It makes chronological view of events very hard.
"All events" replay mode doesn't work at all, it replays only first event, then displays something like "Time to next Event 665 seconds" and nothing happens anymore.
And controls under the image works strange, sometimes it's ok, sometimes they doesn't work at all, sometimes Previous returns me to the beginning of current event, not previous...
lobzik
Re: event replay?
Post by lobzik »
No one having this issue or no one needs to replay events from all monitors?
I did some research yesterday. It looks like zms knows nothing about event filters, it just streams events from selected monitor one by another.
Stream request URL is 192.168.2.100/cgi-bin/nph-zms?source=event&mode=jpeg&event=2467&frame=1&scale=100&rate=100&maxfps=10&replay=gapless&connkey=365026&rand=1359371188 - there is no filter parameters.
However, Referer header of request contains everything I need: /zm/?view=event&eid=2467&filter[terms][0][attr]=DateTime&filter[terms][0][op]=%3E%3D&filter[terms][0][val]=-1+hour&sort_field=StartTime&sort_asc=1&page=1
I'm now trying to modify zms.cpp so it can take filter parameters from Referer header.
