This must be quite simple issue, because I've spent weeks to trying resolve it without luck.
My system is ClearOS 6.3.0 (RedHat fork) 64-bit. Capture device is EasyCap model002 (stk1160). I have upgraded kernel to 3.7.5-1.el6.elrepo.x86_64 because it has stk1160 driver built-in.
I can get picture with:
ffmpeg -f video4linux2 -i /dev/video0 -vframes 1 test.jpg
Feb 9 18:18:58 kaappi zmdc[6081]: INF [Starting pending process, zmc -d /dev/video0]
Feb 9 18:18:58 kaappi zmdc[6081]: INF ['zmc -d /dev/video0' starting at 13/02/09 18:18:58, pid = 6186]
Feb 9 18:18:58 kaappi zmdc[6186]: INF ['zmc -d /dev/video0' started at 13/02/09 18:18:58]
Feb 9 18:18:58 kaappi zma_m1[6120]: WAR [Waiting for capture daemon]
Feb 9 18:18:58 kaappi zmc_dvideo0[6186]: INF [Starting Capture]
Feb 9 18:18:58 kaappi kernel: stk1160: queue_setup: buffer count 8, each 829440 bytes
Feb 9 18:18:58 kaappi zmc_dvideo0[6186]: FAT [Failed to set camera source 0: Device or resource busy]
Feb 9 18:18:58 kaappi zmdc[6081]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
# v4l2-ctl -s pal
Standard set to 000000ff
# v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : stk1160
Card type : stk1160
Bus info : usb-0000:02:02.0-1
Driver version: 3.7.5
Capabilities : 0x85000001
Video Capture
Read/Write
Streaming
Format Video Capture:
Width/Height : 720/576
Pixel Format : 'UYVY'
Field : Interlaced
Bytes per Line: 1440
Size Image : 829440
Colorspace : Broadcast NTSC/PAL (SMPTE170M/ITU601)
Video input : 0 (Composite0: ok)
Video Standard = 0x000000ff
PAL-B/B1/G/H/I/D/D1/K
Streaming Parameters Video Capture:
Frames per second: 25.000 (25/1)
Read buffers : 2
Priority: 2
Also i've also tested my hardware with "zoneminder virtual appliance" and that works ok.
Does anybody have been stuck with this and get it working?
Thank's for reading and more thanks for possible solution.
-- Jarkko
