[solved]analog cams=horrible image & crazy frames
Posted: Sun Feb 10, 2013 1:41 pm
Hi guys,
I have been using zm at home for about three weeks now. Bought a couple of low end cameras, some siamese coax cable and two used Kodicom 4400R cards to play with.
PC Hardware:
- AMD Athlon X2 4000 with 3 GB RAM, 160 GB hard drive
- Asrock AliveNF6G-VSTA motherboard
- Fedora 18 i686
- zm 1.25 using shared memory instead of mmap
- dual Kodicom 4400R PCI, so that would be 8 x BT878a chips
Front porch (Modetect 1) /dev/video0: 600TVL minidome with 1/3" Sony Super HAD CCD II sensor, 30 x 5mm IR LEDs, waterproof, fixed 3.6mm lens
Modetect @ 12 FPS, PAL BGR24 720x576
Corridor - (Modetect 2) /dev/video1: 420TVL minidome with 1/4" Sony CCD sensor, 24 x 5mm IR LEDs, waterproof, fixed 3.6mm lens
Modetect @ 15 FPS, PAL BGR24 640x480
Both are generic Chinese cameras sold in my country using the Nixzen brand.
I know that the cameras are pretty lousy, but I am also struggling with the capture itself. None of these problems appear in the images if I use xawtv or tvtime.
Problem 1: horizontal lines in frames with movement. See image1.jpg. Do I need to activate some kind of comb filter?
Problem 2: frames with ghosts
In the same frame I get two images of a person, the current one and an old one, from 5 or 6 frames ago. See image2.jpg. Sounds like a software bug since I don't think the camera has any frame buffers.
Problem 3: image seems to blend two frames in one. Check out image1 and look at the girl's foot in the bottom right. It's in two places in the same image. Is this done on purpose to make the transition between frames smoother?
Problem 4: frames out of sequence.
Could be related to problem 2. If I am walking from left to right in the image, suddenly for a single frame I appear to the left again and then the next frame continues in the right sequence. You would need to see a whole event, but believe me it happens very frequently and it is easy to reproduce.
I would like to solve these three issues before buying more cameras. Please check out the attached frames. I can upload the whole event to mega.co.nz if you would like to see the whole sequence.
Thanks in advance,
Axel
PC Hardware:
- Fedora 18 i686
Thanks in advance,
Axel
