Page 1 of 1
Only want video captured instead of jpg files
Posted: Wed Feb 13, 2013 1:45 pm
by planetpounder
I just succesfully installed zoneminder and connected axis cameras using this tutorial
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
The event directory only shows jpg files and i really want it to be only video files.
I'm stuck at it, do you have any idea how to configure this?
Re: Only want video captured instead of jpg files
Posted: Wed Feb 13, 2013 9:15 pm
by theforce
ZM only saves jpg's. You can export as video through the web interface. I dont think you can have ZM automatically save as video instead of jpg.
Is there a reason you need videos instead of jpg's?
Posted: Wed Feb 13, 2013 9:41 pm
by planetpounder
You are right, figured it out
It works okay for me now, thanks.
