Page 1 of 1
No streams when logged in with password
Posted: Mon Feb 25, 2013 12:32 pm
by troijers
When i login to ZM with a password protected login i can't view any streams.
When i disable login auth it works just fine.
Anybody?
Tim
Re: No streams when logged in with password
Posted: Mon Feb 25, 2013 12:38 pm
by jameswilson
Which auth system are you using?
Posted: Mon Feb 25, 2013 1:03 pm
by troijers
This is what is see when i want to open a stream after logging in with a password
in /var/syslog
ERR [Unable to authenticate user]
Posted: Mon Feb 25, 2013 1:04 pm
by troijers
jameswilson wrote:Which auth system are you using?
Built in, Plain text.
Posted: Mon Feb 25, 2013 1:09 pm
by jameswilson
your opening a stream from the zm console or from calling a url?
Posted: Mon Feb 25, 2013 1:30 pm
by troijers
jameswilson wrote:your opening a stream from the zm console or from calling a url?
From my brower on the PC where ZM is running (localhost). Login in without a password it works just fine..
Looks like the popup windows to show the stream doesn't remember the password entered when login into ZM console.
Posted: Mon Feb 25, 2013 1:49 pm
by jameswilson
That shouldnt matter as the auth string for the current login is passed.
by jameswilson
Posted: Mon Feb 25, 2013 1:58 pm
by troijers
jameswilson wrote:That shouldnt matter as the auth string for the current login is passed.
Okay, well i'm stuck... really don't know what else to check.
Tried several browsers, no succes!
Posted: Wed Feb 27, 2013 9:31 pm
by jameswilson
Do you restart zm, logout etc after enabling auth?
Posted: Thu Feb 28, 2013 2:28 pm
by troijers
jameswilson wrote:Do you restart zm, logout etc after enabling auth?
There are three options for auth: hash, plain en none.
Used "none", now i can watch the stream after login
Getting more than one cam working at the same time is a bigger problem
