Page 1 of 1
Multiple Hard Drives
Posted: Thu Feb 28, 2013 9:25 pm
by jameswilson
I have added another 2tb drive and want to use this for event storage. I normally do this with raid but this box is 12.10 ubuntu and no mdadm. Plus its live. Can i add it somehow?
Re: Multiple Hard Drives
Posted: Fri Mar 01, 2013 6:36 am
by Flasheart
You can't "add" another drive to ZM's storage in the sense of topping it up. There needs to be a single point, which by default is in /var, is easy to move to another drive or resource mounted locally, or if you needed serious storage, raid would indeed be the answer.
You can move zm's mount point by following this;
http://www.zoneminder.com/wiki/index.ph ... Hard_Drive
Posted: Fri Mar 01, 2013 12:45 pm
by jameswilson
Thanks Ill have a look over the weekend. I guess ill have to make a raid 0 array from what is left of sda and all of sdb, mount that as /var and copy it all over.
