Starting ZM inside a FreeBSD jail fails - workaround provide
hjf
Post by hjf »
There's a problem with the zmpkg.pl script under FreeBSD. When auto-started inside a Jail, FreeBSD doesn't use the "start" argument, but it uses "quietstart" (and quietstop, etc). So ZM doesn't automatically start (the web interface loads but it shows as "Stopped").
As a workaround, I added the following at line 54 in zmpkg.pl:
if ($command =~ /^quiet(.*)/) {$command=$1;}
right before
if ( !$command || $command !~ /^(?:start|stop|restart|status|logrot|faststart|faststop)$/ )
Cheers,
Hernán
