Page 1 of 1
No picture on ZoneMinder! (using wanscam and WGCA54 Linksys)
Posted: Sun Mar 31, 2013 9:27 pm
by thevinz
Hello
First of all, sorry for my english. I'll try to explain my probelm as clear as possible
I'have install ZoneMinder an a debian computer (Debian Linux 5)
I have setup zone minder using "apt-get install zoneminder"
I have add a Wanscam camera using this page: http://www.zoneminder.com wiki index.php Wanscam_FR4020A2_PT
The camera seem to have been succesfully installed but wen I try to view the picture, I have a brocken picture istead of the webcam picture.
I have the same problem using a linksys WVC54GCA camera with the parameters:
admin:******@192.168.0.98 as remote host name
img/mjpeg.jpg as remote host path
I have a brocken picture istead of the webcam picture. (the link http admin:*****@192.168.0.98:98 img/mjpeg.jpg display the picture !)
Can someone help me ?
Thanks a lot
Re: No picture on ZoneMinder! (using wanscam and WGCA54 Link
Posted: Mon Apr 01, 2013 5:55 am
by Flasheart
Usual problem is; http://www.zoneminder.com/wiki/index.ph ... esolutions.
If not that, read the faq and if still not sorted, we're going to need some logs to help diagnose.
Posted: Mon Apr 01, 2013 7:32 am
by thevinz
Hello
Thank you for this answer but I do not have seen anything on the FAQ about my problem.
I have found that:
When I se the apache2 log when I try to see streming, the error log display anything else that a warning PHP Deprecated for the ereg() php function.
The access log tells that the cgi-bin programm is found:
192.168.0.24 - - [01/Apr/2013:09:26:44 +0200] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=1&scale=100&auth=ce8c1569cfda23a6f2123c46313625fc&connkey=963672&rand=1364801204 HTTP/1.1" 200 560544 "*************:82/zm/index.php?view=watch&mid=1" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.22 (KHTML, like Gecko) Chrome/25.0.1364.172 Safari/537.22"
So is seem not to be an apache2 problem ...
I can give you as log as you need to found the solution. Juste tell me what log you need !
Thank you !
Posted: Mon Apr 01, 2013 11:46 am
by Flasheart
The shared memory tweak is what you NEED to do unless you're using a newer build with mmap enabled, if you want to view streams > 320x240
The php issue is a warning. Google will tell you how to tweak that, and it's discussed elsewhere in this forum too, but it shouldn't cause zm not to work.
Posted: Mon Apr 01, 2013 7:39 pm
by thevinz
Ok thank you for this answer.
Any other idea ?
thank you !
Posted: Wed Apr 10, 2013 7:02 am
by thevinz
Hello
nobody to help me ?
It's very bad. I have juste mounted a dedicated server to use zoneminder, and i cannot use it becaus of my problem !
Posted: Mon May 06, 2013 8:16 am
by thevinz
Up, my problem is not solved.
Can someone help me or give me a way to search ?
