Page 1 of 1
Zoneminder Not Capturing Events
Posted: Tue Apr 02, 2013 6:32 pm
by resuni
For some reason I cannot get Zoneminder to capture events. I have tried setting the function to either record or mocord but events still do not show up in the list. What else do I have to do to enable events?
Re: Zoneminder Not Capturing Events
Posted: Wed Apr 03, 2013 1:54 pm
by PacoLM
Some logs or more details will help to help...
Posted: Wed Apr 03, 2013 4:07 pm
by resuni
What other details do you need? I can tell you I'm using a pair of PV-143 cards. Where are the log files you want me to post?
Posted: Thu Apr 04, 2013 6:33 am
by PacoLM
/var/log/syslog or enable the log option and attach a screenshot.
Posted: Thu Apr 04, 2013 4:50 pm
by resuni
Here is my /var/log/syslog. I couldn't find the option to enable logging in Zoneminder.
Posted: Thu Apr 04, 2013 6:49 pm
by PacoLM
Seems a permission problem:
FAT [Can't symlink '1' to 'Monitor-1': Permission denied]
Try:
chown -R www:www /usr/local/www/zoneminder
(change the path to your path)
Hope it helps,
PacoLM
Posted: Thu Apr 04, 2013 11:59 pm
by resuni
That seemed to do the trick. I ran `chown -R www-data:www-data /var/cache/zoneminder/images/` then `chown -R www-data:www-data /var/cache/zoneminder/events/` and events seem to be sucessfully listing. Thanks!
Posted: Fri Apr 05, 2013 6:44 am
by PacoLM
