Page 1 of 1
"No main content type" while trying to open rtsp camera
Posted: Thu Apr 11, 2013 2:40 pm
by Edu
Hello Everyone,
I have 4 cameras that send a RTSP stream as follows:
rtsp://192.168.1.105/live/mpeg4
I can access and view the cameras if I open the stream with a video program like VLC, but when I configure them in ZoneMinder and then try to open the image, I get a "No main content type" message after the Java applet loaded.
Do you know what causes that and how to solve it?
I can ping the cam IP from my ZM server.
Bellow is the cam configuration in ZoneMinder:
- ZM1.png (34.61 KiB) Viewed 3531 times
- ZM2.png (37.51 KiB) Viewed 3531 times
Thanks!
Re: "No main content type" while trying to open rtsp camera
Posted: Thu Apr 11, 2013 11:14 pm
by bb99
Change your monitor general tab source type to ffmpeg and reconfigure.
Posted: Fri Apr 12, 2013 1:02 pm
by Edu
Hi, I get the same error with the following configuration
- ZM3.png (31.69 KiB) Viewed 3518 times
I also tried using rtsp://192.168.1.105/live/mpeg4 as source path
Posted: Fri Apr 19, 2013 1:12 pm
by Edu
Still having this issue, any ideas?
Posted: Sat Apr 20, 2013 10:33 pm
by bb99
View your camera in a browser and look at the source or properties and verify the resolution is 640*480. If it is set the camera resolution in it's firmware to 320*240 and adjust in ZM also to see what happens.
Posted: Sat Apr 20, 2013 10:35 pm
by bb99
Also verify the cameras path as you read through the source info.
Posted: Mon Apr 22, 2013 6:09 pm
by Edu
Well, that's the thing, I can view the stream from VideoLAN but not from ZoneMinder,
VideoLAN says the frame is 640x480, and it opens it with that URL
Is there any way to check if ZoneMinder actually gets the stream but is not able to show it in the browser?
Posted: Wed Apr 24, 2013 3:12 pm
by Edu
I was using Ubuntu 10.04 LTS
I've rebuilt with Ubuntu 12.10 64bits, no password for the mySQL root, and it worked.
I followed this guide:
http://kirichkov.com/368/howto-make-a-c ... oneminder/
