[SOLVED]: Config Table deletes new entries
maxrpi
Post by maxrpi »
I'm trying to customize the Option window to add GSM SMS support over Android to my ZM configuration. In order to do that, I tried to add new variables to the Config table to allow the options.php to retrieve the info, but after a while the new entries in the table are deleted. i can't tell how much time elapsed...last night worked flawlessly, but this morning after state change they disappeared againg. since it happened twice, i suppose there should be some process which is checking the entries...
i'm stuck...does anyone can help?
thank you
max
maxrpi
Re: Config Table deletes new entries
Post by maxrpi »
just realized i didn't update ConfigData.pm with the new variables. I'll make these updates as well. i will post the results.
maxrpi
Post by maxrpi »
hello again,
just tried to modify ConfigData.pm adding the new variables in it. It does work. The sub to reload the configuration is called by zmupdate at each restart.
max
