Zavio mjpeg video with sound confuses ZM
marcmerlin
Post by marcmerlin »
Currently, I'm forced to use mjpeg over http with my zavio f3210.
Unfortunately, if I enable audio in my stream, so that I can get it over VLC for side monitoring, ZM gets confused with the stream and refuses to use it:
ERR [Found unsupported content type 'audio/basic']
ERR [Unable to get response]
ERR [Failed to capture image from monitor 9 (0/1)]
http simple with /stream?uri=video.pro1 as per http://www.zoneminder.com/wiki/index.php/Zavio
I'm ok with audio turned off, but I'd rather have it back on for when I use VLC.
Is there a bug on this, and is there a workaround?
Thanks,
Marc
