I have spent nearly a week to solve my ZM problem, including by searching similar issue on www and zoneminder forum, but with no luck.
I use Debian 6.07, Koha 3.10, and ZM 1.24. When I installed Koha only on Debian, it's OK. When installed ZM only on Debian, it's OK too (working fine). But when I installed both Koha and ZM on Debian (whether installing Koha first and ZM later, or vice versa - ZM first Koha later) this generates problems in Zoneminder : 1) Monitor-1 and Monitor-2 (between Name & Refresh) cannot be clicked (no hyperlinks) so that I cannot view the streaming; 2) Cycle/Montage cannot be clicked as well; 3) The "Stopped" in "Zoneminder Console - Stopped - v1.24.2" cannot be changed into "Running" (no effect when clicked). [See the Screenshot]. I am not sure whether this is a script conflict between Koha and ZM or not. Anyway, hope anyone could help me...
[PS: sorry mistyped the second IP in the screenshot because of installing and reinstalling the software. With correct IPs, it also doesn't work]
Koha vs Zoneminder? No Hyperlinks, please Help
- Screenshot Koha-ZM
- Screenshot-2.PNG (218.9 KiB) Viewed 5919 times
Re: Koha vs Zoneminder? No Hyperlinks, please Help
Read this post: http://www.zoneminder.com/forums/viewto ... t=mootools
Also, check the logs, maybe you could see any clue of why zm is not starting.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
Thank you for the response. I am a newbie so that I have to learn mootools. I have tried to restart the computer, open Koha, open ZM Zonsole, visit Zoneminder website, and back to ZM Console to see what happen via the syslog. Unfortunately, I haven't found any clue yet (. I tried to post the edited syslog, but failed.
Here is the syslog of my zoneminder, and I have no idea. I tried to increase the debug level, but with no effect.
May 4 20:30:15 debian zmc_m2[3763]: INF [Starting Capture]
May 4 20:30:22 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:30:22 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:30:22, pid = 3764]
May 4 20:30:22 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:30:22 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:30:22, pid = 3765]
May 4 20:30:22 debian zmdc[3764]: INF ['zmc -m 1' started at 13/05/04 20:30:22]
May 4 20:30:22 debian zmdc[3765]: INF ['zmc -m 2' started at 13/05/04 20:30:22]
May 4 20:30:22 debian zmc_m1[3764]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:22 debian zmc_m2[3765]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:22 debian zmc_m1[3764]: INF [Starting Capture]
May 4 20:30:22 debian zmc_m2[3765]: INF [Starting Capture]
May 4 20:30:34 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:30:34 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:30:34, pid = 3766]
May 4 20:30:34 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:30:34 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:30:34, pid = 3767]
May 4 20:30:34 debian zmdc[3766]: INF ['zmc -m 1' started at 13/05/04 20:30:34]
May 4 20:30:34 debian zmdc[3767]: INF ['zmc -m 2' started at 13/05/04 20:30:34]
May 4 20:30:34 debian zmc_m1[3766]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:34 debian zmc_m2[3767]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:34 debian zmc_m2[3767]: INF [Starting Capture]
May 4 20:30:34 debian zmc_m1[3766]: INF [Starting Capture]
May 4 20:30:56 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:30:56 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:30:56, pid = 3772]
May 4 20:30:56 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:30:56 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:30:56, pid = 3773]
May 4 20:30:56 debian zmdc[3772]: INF ['zmc -m 1' started at 13/05/04 20:30:56]
May 4 20:30:56 debian zmdc[3773]: INF ['zmc -m 2' started at 13/05/04 20:30:56]
May 4 20:30:56 debian zmc_m1[3772]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:56 debian zmc_m2[3773]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:30:56 debian zmc_m1[3772]: INF [Starting Capture]
May 4 20:30:56 debian zmc_m2[3773]: INF [Starting Capture]
May 4 20:31:38 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:31:38 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:31:38, pid = 3781]
May 4 20:31:38 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:31:38 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:31:38, pid = 3782]
May 4 20:31:38 debian zmdc[3781]: INF ['zmc -m 1' started at 13/05/04 20:31:38]
May 4 20:31:38 debian zmdc[3782]: INF ['zmc -m 2' started at 13/05/04 20:31:38]
May 4 20:31:38 debian zmc_m1[3781]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:31:38 debian zmc_m2[3782]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:31:38 debian zmc_m1[3781]: INF [Starting Capture]
May 4 20:31:38 debian zmc_m2[3782]: INF [Starting Capture]
May 4 20:33:00 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:33:00 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:33:00, pid = 3789]
May 4 20:33:00 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:33:00 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:33:00, pid = 3790]
May 4 20:33:00 debian zmdc[3789]: INF ['zmc -m 1' started at 13/05/04 20:33:00]
May 4 20:33:00 debian zmdc[3790]: INF ['zmc -m 2' started at 13/05/04 20:33:00]
May 4 20:33:00 debian zmc_m1[3789]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:33:00 debian zmc_m2[3790]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:33:00 debian zmc_m1[3789]: INF [Starting Capture]
May 4 20:33:00 debian zmc_m2[3790]: INF [Starting Capture]
May 4 20:35:42 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:35:42 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:35:42, pid = 3835]
May 4 20:35:42 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:35:42 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:35:42, pid = 3836]
May 4 20:35:42 debian zmdc[3836]: INF ['zmc -m 2' started at 13/05/04 20:35:42]
May 4 20:35:42 debian zmdc[3835]: INF ['zmc -m 1' started at 13/05/04 20:35:42]
May 4 20:35:42 debian zmc_m1[3835]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:35:42 debian zmc_m2[3836]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:35:42 debian zmc_m1[3835]: INF [Starting Capture]
May 4 20:35:42 debian zmc_m2[3836]: INF [Starting Capture]
May 4 20:38:55 debian zmfilter[3926]: INF [Scanning for events using filter '_TempFilter1367671135']
May 4 20:38:59 debian zmfilter[3933]: INF [Scanning for events using filter '_TempFilter1367671138']
May 4 20:41:04 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:41:04 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:41:04, pid = 4000]
May 4 20:41:04 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:41:04 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:41:04, pid = 4001]
May 4 20:41:04 debian zmdc[4000]: INF ['zmc -m 1' started at 13/05/04 20:41:04]
May 4 20:41:04 debian zmdc[4001]: INF ['zmc -m 2' started at 13/05/04 20:41:04]
May 4 20:41:04 debian zmc_m2[4001]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:41:04 debian zmc_m1[4000]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:41:04 debian zmc_m1[4000]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04000]
May 4 20:41:04 debian zmc_m2[4001]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04001]
May 4 20:41:04 debian zmc_m2[4001]: INF [Starting Capture]
May 4 20:41:04 debian zmc_m1[4000]: INF [Starting Capture]
May 4 20:51:06 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 20:51:06 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 20:51:06, pid = 4108]
May 4 20:51:06 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 20:51:06 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 20:51:06, pid = 4109]
May 4 20:51:06 debian zmdc[4108]: INF ['zmc -m 1' started at 13/05/04 20:51:06]
May 4 20:51:06 debian zmdc[4109]: INF ['zmc -m 2' started at 13/05/04 20:51:06]
May 4 20:51:06 debian zmc_m1[4108]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:51:06 debian zmc_m2[4109]: INF [Debug Level = 0, Debug Log = <none>]
May 4 20:51:06 debian zmc_m2[4109]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04109]
May 4 20:51:06 debian zmc_m1[4108]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04108]
May 4 20:51:06 debian zmc_m2[4109]: INF [Starting Capture]
May 4 20:51:06 debian zmc_m1[4108]: INF [Starting Capture]
May 4 21:01:08 debian zmdc[3725]: INF [Starting pending process, zmc -m 1]
May 4 21:01:08 debian zmdc[3725]: INF ['zmc -m 1' starting at 13/05/04 21:01:08, pid = 4217]
May 4 21:01:08 debian zmdc[3725]: INF [Starting pending process, zmc -m 2]
May 4 21:01:08 debian zmdc[3725]: INF ['zmc -m 2' starting at 13/05/04 21:01:08, pid = 4218]
May 4 21:01:08 debian zmdc[4217]: INF ['zmc -m 1' started at 13/05/04 21:01:08]
May 4 21:01:08 debian zmdc[4218]: INF ['zmc -m 2' started at 13/05/04 21:01:08]
May 4 21:01:08 debian zmc_m1[4217]: INF [Debug Level = 0, Debug Log = <none>]
May 4 21:01:08 debian zmc_m2[4218]: INF [Debug Level = 0, Debug Log = <none>]
May 4 21:01:08 debian zmc_m1[4217]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04217]
May 4 21:01:08 debian zmc_m2[4218]: INF [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04218]
May 4 21:01:08 debian zmc_m1[4217]: INF [Starting Capture]
May 4 21:01:08 debian zmc_m2[4218]: INF [Starting Capture]
MySql? Both are heavy users. Exactly what's wrong I can't say but that's where I'd start.
After a painful struggle, I found a solution. Previously, I have tried with three different computers but with the same results/problems. Then, I tried with other Linux Distro, and amazingly it works. I compared the configuration, and I found the main culprit is the port (port 80). After reinstalling a fresh debian, and give Koha an INTRAPORT="8000" and OPACPORT="8001", Koha and Zoneminder now live in harmony. Thanks for the encouragement in finding a solution.
