Fedora 19 Installation help.
Posted: Sat May 04, 2013 6:04 pm
Is anyone game to help me through a new installation on Fedora 19? I am going by the f18 installation instructions but am having no luck. I am stuck at This point.
I have not edited the config file where i think it says to delete this line.
I had an install on f17 that was flawless in function. But i am in the dark now. things seem to have changed a little.
Thanks for any help!
EDIT---------------------------------------------
Could not connect to database: Access denied for user 'zmuser'@'localhost' (using password: YES)
EDIT-----------------------------------------------
This is what i get from the server! hope it helps.
George....
Thanks for using MariaDB!
[root@zoneminder ~]# mysql -u root -p < /usr/share/zoneminder/db/zm_create.sql
Enter password:
Enter password:
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 12
Server version: 5.5.30-MariaDB MariaDB Server
Copyright (c) 2000, 2013, Oracle, Monty Program Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
George....
