Page 1 of 1
[Help] zoneminder 2x recording
Posted: Wed May 15, 2013 12:34 pm
by furyzika
I had put a name to the cameras, I decided to change the name. Now is creating events with the old name and the new.
PIC: in attachment
Anyone know how to fix it?
sorry for bad english.
Re: [Help] zoneminder 2x recording
Posted: Thu May 16, 2013 6:03 pm
by mikb
That looks normal, in my events directory there are actual numbered directories containing the events, and symbolic links from "fake" directories that have the name of the cameras
drwxr-xr-x 2 apache apache 4096 Mar 30 00:02 10
drwxr-xr-x 3 apache apache 4096 Apr 1 15:13 4
drwxr-xr-x 3 apache apache 4096 Mar 25 11:52 5
drwxr-xr-x 3 apache apache 4096 Mar 26 11:52 6
drwxr-xr-x 3 apache apache 4096 Apr 6 19:01 7
drwxr-xr-x 3 apache apache 4096 Apr 10 15:16 8
drwxr-xr-x 2 apache apache 4096 Mar 30 00:02 9
lrwxrwxrwx 1 apache apache 1 Mar 25 10:43 CAM01_FRONT_CZ -> 5
lrwxrwxrwx 1 apache apache 1 Mar 28 12:16 CAM02_FRONT_RW -> 4
lrwxrwxrwx 1 apache apache 1 Mar 24 17:03 CAM03_FRONT_LW -> 6
lrwxrwxrwx 1 apache apache 1 Mar 24 17:03 CAM04_REAR_CW -> 7
lrwxrwxrwx 1 apache apache 1 Mar 24 17:04 CAM05_FRONT_GW -> 8
lrwxrwxrwx 1 apache apache 1 Mar 24 17:05 CAM06 -> 9
lrwxrwxrwx 1 apache apache 2 Mar 24 17:06 CAM07 -> 10
Events that were made before you changed the name will be stored as the old name, events from after will take the new name.
If your old names were just 1 2 3 4, then I don't see a problem here. Maybe I misunderstood the question
Posted: Thu May 16, 2013 8:40 pm
by furyzika
the problem that is occupying space 2x in HD right?
ex: right would store 1 gb in which case store 2gb understand?
Posted: Fri May 17, 2013 5:20 pm
by mikb
furyzika wrote:the problem that is occupying space 2x in HD right?
Ah -- if that's what you were worried about, then no.
That's the beauty of a symbolic link. You are looking at a graphical representation that hides the underlying details, it looks like there are two directories with identical contents. But there isn't.
Zoneminder (internally) uses the numbered directories, they have the actual events and video in.
The directories with "friendly names" are just a link to the underlying numbered directory.
It looks like everything is working normally to me!
Posted: Fri May 17, 2013 5:47 pm
by furyzika
ooo thank you. you know this error?
LOG:
message:socket_sendto( /tmp/zm/zms-515252s.sock ) failed: No such file or directory
file:/usr/share/zoneminder/includes/functions.php
line:2322
Posted: Sun May 19, 2013 8:31 pm
by mikb
furyzika wrote:ooo thank you. you know this error?
LOG:
line:2322
I've seen it, but not understood or fixed it -- it's something to do with your "live view" of a camera feed breaking.
May 19 16:54:39 perkin web_php[24474]: ERR [socket_sendto( /tmp/zm/zms-574376s.sock ) failed: Connection refused]
or
May 19 17:08:10 perkin web_php[22821]: ERR [socket_sendto( /tmp/zm/zms-534260s.sock ) failed: No such file or directory]
