ZM still recording some cams even when service is stopped
I'm burning in a test with 16 cams recording and the ZM streams being monitored by a webpage. Running great for a solid 7 days, and then it ran of memory and the system started killing processes. ZM service stopped itself but 12 of the 16 cams are still recording even though the service is stopped. The log shows green as well, while there are 4 cameras not recording. I just thought I would report this odd behavior if anyone cares.
Re: ZM still recording some cams even when service is stoppe
To check what processes are running you can always run top or top. How ram does system have?
I didn't think to check top command at the time, i'll try it if it happens again.
The system has 4 GB RAM.
