Disk Writes
collins
Disk Writes
Post by collins »
Hello
I am wondering if there is something that can be done about disk writes? I am running zoneminder on Ubuntu with 8Gig of ram with 3G in use . I have two X10 Airsight setup with Simple HTTP and /videostream.cgi path. It all work just great love it but it is constantly writing to disk. Is there something I can do so it will untilize more memory and only write to disk if a event is triggered. I can add more memory to the PC if need or if it will help.
I have only made the memory changes a advised by the wiki,.
root@zoneminder:~# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 524288
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages Limits --------
max queues system wide = 1530
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
root@zoneminder:~#
