mootools not found if ZM is accessed from outside LAN
td
Post by td »
after upgrading my server to openSuse 12.3 and installing ZM (1.25.0; performance patch version by mastertheknife) the following strange error occurs:
Accessing from LAN there is no problem, accessing from outside LAN (server is addressed directly via IP), I get the error box "MooTools not found! Please check that it was installed correctly in ZoneMinder web root" on each click; ZM is nonetheless usable. Obviously MooTools are installed because there aren't any problems on usage within the LAN.
For access from outside authorisation (.htaccess) is necessary. Directory rights below the zm directory are correct (all set to wwwrun-www).
Any ideas?
TD
