GeoVision GV-800 Ubuntu Precise Pangolin does not work!
nrivoli
Post by nrivoli »
Hi.
I have this card
[   11.233802] bttv: driver version 0.9.19 loaded
[   11.233804] bttv: using 8 buffers with 2080k (520 pages) each for capture
[   11.233843] bttv: Bt8xx card found (0)
[   11.233910] bttv: 0: Bt878 (rev 17) at 0000:05:00.0, irq: 16, latency: 32, mmio: 0xf0007000
[   11.233922] bttv: 0: detected: GeoVision GV-800(S) (master) [card=157], PCI subsystem ID is 800a:763d
[   11.233923] bttv: 0: using: Geovision GV-800(S) (master) [card=157,autodetected]
[   11.234656] bttv: 0: tuner absent
[   11.234688] bttv: 0: registered device video0
[   11.234706] bttv: 0: registered device vbi0
[   11.234728] bttv: 0: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[   11.262750] bttv: PLL set ok
[   11.266040] bttv: Bt8xx card found (1)
[   11.266052] bttv: 1: Bt878 (rev 17) at 0000:05:04.0, irq: 16, latency: 32, mmio: 0xf0005000
[   11.266090] bttv: 1: detected: GeoVision GV-800(S) (slave) [card=158], PCI subsystem ID is 800b:763d
[   11.266091] bttv: 1: using: Geovision GV-800(S) (slave) [card=158,autodetected]
[   11.266176] bttv: 1: tuner absent
[   11.266197] bttv: 1: registered device video1
[   11.266218] bttv: 1: registered device vbi1
[   11.266240] bttv: 1: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[   11.294734] bttv: PLL set ok
[   11.298014] bttv: Bt8xx card found (2)
[   11.298032] bttv: 2: Bt878 (rev 17) at 0000:05:08.0, irq: 16, latency: 32, mmio: 0xf0003000
[   11.298084] bttv: 2: detected: GeoVision GV-800(S) (slave) [card=158], PCI subsystem ID is 800c:763d
[   11.298085] bttv: 2: using: Geovision GV-800(S) (slave) [card=158,autodetected]
[   11.298162] bttv: 2: tuner absent
[   11.298219] bttv: 2: registered device video2
[   11.298263] bttv: 2: registered device vbi2
[   11.298293] bttv: 2: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[   11.326726] bttv: PLL set ok
[   11.330006] bttv: Bt8xx card found (3)
[   11.330020] bttv: 3: Bt878 (rev 17) at 0000:05:0c.0, irq: 16, latency: 32, mmio: 0xf0001000
[   11.330034] bttv: 3: detected: GeoVision GV-800(S) (slave) [card=158], PCI subsystem ID is 800d:763d
[   11.330034] bttv: 3: using: Geovision GV-800(S) (slave) [card=158,autodetected]
[   11.330097] bttv: 3: tuner absent
[   11.330129] bttv: 3: registered device video3
[   11.330151] bttv: 3: registered device vbi3
[   11.330173] bttv: 3: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[   11.358734] bttv: PLL set ok
it works, really works.
Also works from www-data.
I did modify the bttv.conf
streamer -c /dev/video0 -i 0 -o test.jpeg works!
streamer -c /dev/video0 -i 0 -D v4l2 -o test.jpeg works too!
But zoneminder keeps saying
Jul 19 20:52:50 qwerty zmpkg[2841]: INF [Command: stop]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmupdate.pl -c' stopping at 13/07/19 20:52:50]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmupdate.pl -c' exited, signal 14]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmfilter.pl ' stopping at 13/07/19 20:52:50]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmfilter.pl ' exited, signal 14]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmwatch.pl ' stopping at 13/07/19 20:52:50]
Jul 19 20:52:50 qwerty zmdc[2551]: INF ['zmwatch.pl ' exited, signal 14]
Jul 19 20:53:00 qwerty zmdc[2551]: INF [Server shutdown at 13/07/19 20:53:00]
Jul 19 20:53:19 qwerty zmpkg[2900]: INF [Command: start]
Jul 19 20:53:19 qwerty zmdc[2910]: INF [Server starting at 13/07/19 20:53:19]
Jul 19 20:53:22 qwerty zmdc[2910]: INF ['zmc -d /dev/video0' starting at 13/07/19 20:53:22, pid = 2934]
Jul 19 20:53:22 qwerty zmdc[2934]: INF ['zmc -d /dev/video0' started at 13/07/19 20:53:22]
Jul 19 20:53:23 qwerty zmc_dvideo0[2934]: INF [Starting Capture]
Jul 19 20:53:23 qwerty zmc_dvideo0[2934]: FAT [Failed to get picture attributes: Inappropriate ioctl for device]
Jul 19 20:53:23 qwerty zmdc[2910]: INF [Can't find child with pid of '2911']
Jul 19 20:53:23 qwerty zmdc[2910]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Jul 19 20:53:23 qwerty zmdc[2910]: INF [Starting pending process, zmc -d /dev/video0]
Jul 19 20:53:23 qwerty zmdc[2910]: INF ['zmc -d /dev/video0' starting at 13/07/19 20:53:23, pid = 2937]
Jul 19 20:53:23 qwerty zmdc[2937]: INF ['zmc -d /dev/video0' started at 13/07/19 20:53:23]
Jul 19 20:53:23 qwerty zmc_dvideo0[2937]: INF [Starting Capture]
Jul 19 20:53:23 qwerty zmc_dvideo0[2937]: FAT [Failed to get picture attributes: Inappropriate ioctl for device]
Jul 19 20:53:23 qwerty zmdc[2910]: INF ['zmfilter.pl' starting at 13/07/19 20:53:23, pid = 2940]
Jul 19 20:53:23 qwerty zmdc[2940]: INF ['zmfilter.pl' started at 13/07/19 20:53:23]
Jul 19 20:53:23 qwerty zmdc[2910]: INF ['zmwatch.pl' starting at 13/07/19 20:53:23, pid = 2944]
Jul 19 20:53:23 qwerty zmdc[2944]: INF ['zmwatch.pl' started at 13/07/19 20:53:23]
Jul 19 20:53:23 qwerty zmfilter[2940]: INF [Scanning for events]
Jul 19 20:53:23 qwerty zmwatch[2944]: INF [Watchdog starting]
Jul 19 20:53:23 qwerty zmwatch[2944]: INF [Watchdog pausing for 30 seconds]
Jul 19 20:53:23 qwerty zmdc[2910]: INF ['zmupdate.pl -c' starting at 13/07/19 20:53:23, pid = 2948]
Jul 19 20:53:23 qwerty zmdc[2948]: INF ['zmupdate.pl -c' started at 13/07/19 20:53:23]
Tested also with and without
cat /etc/modprobe.d/bttv.conf
options bttv gbuffers=16 card=0x9d,0x9e,0x9e,0x9e tuner=0
I don't know how to fix this.
zmu -d /dev/video0 -qv as www-data
Video Device: /dev/video0
General Capabilities
  Driver: bttv
  Card: BT878 video (Geovision GV-800(S
  Bus: PCI:0000:05:00.0
  Version: 3.5.7
  Type: 0x5000015
    Supports video capture (X)
    Does not support video output
    Supports frame buffer overlay
    Supports VBI capture
    Does not support VBI output
    Does not have tuner
    Does not have radio
    Supports read/write i/o (X)
    Does not support async i/o
    Supports streaming i/o (X)
    Standards:
      NTSC
      NTSC-M
      NTSC-M-JP
      NTSC-M-KR
      PAL
      PAL-BG
      PAL-H
      PAL-I
      PAL-DK
      PAL-M
      PAL-N
      PAL-Nc
      PAL-60
      SECAM
      SECAM-B
      SECAM-G
      SECAM-H
      SECAM-DK
      SECAM-L
      SECAM-Lc
  Formats:
    8 bpp, gray (GREY)
    8 bpp, dithered color (HI24)
    15 bpp RGB, le (RGBO)
    15 bpp RGB, be (RGBQ)
    16 bpp RGB, le (RGBP)
    16 bpp RGB, be (RGBR)
    24 bpp RGB, le (BGR3)
    32 bpp RGB, le (BGR4)
    32 bpp RGB, be (RGB4)
    4:2:2, packed, YUYV (YUYV)
    4:2:2, packed, UYVY (UYVY)
    4:2:2, planar, Y-Cb-Cr (422P)
    4:2:0, planar, Y-Cb-Cr (YU12)
    4:2:0, planar, Y-Cr-Cb (YV12)
    4:1:1, planar, Y-Cb-Cr (411P)
    4:1:0, planar, Y-Cb-Cr (YUV9)
    4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
  Bounds: 1063 x 608
  Default: 924 x 576
  Current: 924 x 576
Inputs: 4
  Input 0
    Type: Camera
    Audioset: 00000001
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
    Colour Signal detected
    Horizontal Lock detected
  Input 1
    Type: Camera
    Audioset: 00000001
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
  Input 2
    Type: Camera
    Audioset: 00000001
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
  Input 3
    Type: Camera
    Audioset: 00000001
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
Tested v4l v1 and v2
I followed various manuals but nothing works.
nrivoli
Re: GeoVision GV-800 Ubuntu Precise Pangolin does not work!
Post by nrivoli »
Well finally I got it!
akemapa com /2009/08/14/fixing-monitor-problem-on-zoneminder/
vim /usr/bin/zmdc.pl
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
[b]$ENV{LD_PRELOAD} = '/usr/lib/x86_64-linux-gnu/libv4l/v4l1compat.so';[/b]
my @daemons = (
    'zmc',
    'zma',
    'zmf',
    'zmfilter.pl',
    'zmaudit.pl',
    'zmtrigger.pl',
    'zmx10.pl',
    'zmwatch.pl',
    'zmupdate.pl',
    'zmtrack.pl'
