hi, at the beginning I wanted to apologize for my poor English.
ZoneMinder installed on my Ubuntu Server 13.04 and the program itself works quite well, but even though you connect three different camera image of them did not satisfy me, even worse if the image is encoded as exemplified by the image below. pictube.kmus.pl/?di=6BUC
In the picture are marked with yellow color "function" and "source", now I was able to set the parameters so that everything is green, but the cameras still do not have, such as what Mze be the cause?
zoneminder bad video
Re: zoneminder bad video
Nobody can help me?
- knight-of-ni
I have not used analog cameras tied to a capture card in years so my memory is fuzzy.
Are your cameras NTSC or PAL? Find out and then make sure you have programmed zoneminder accordingly.
Use a tool called xawtv to see if you can see video. If you get video then the problem may be a zonemidner configuration issue. If you cannot see video then the issue is with your hardware, cabling, or the Linux driver for that hardware.
I do not know whether it is PAL or NTSC but I checked under both and nothing. The camera is working because the program VLC I can see the image perfectly.
