I installed ZM 1.25 through virtual image. Seems to run pretty fine so far.
I'm using a Foscam FI8910W camera. I can easily access the camera through my browser, watch the videos and control (move etc.) it.
Now I created the monitor in ZM based on the Wiki.
Yes, I downloaded the additional .pm file and renamed it properly. I changed the needed line to Logger instead of Debug, too. The Foscam users I've configured are operators level, not only visitor. According to the Wiki (and the other five posts here) it should be sufficent.
Unfortunately I can't control the camera through ZM. I can see the control buttons, but nothing happens when clicking on them.
Instead I get erros in logfiles /var/log/syslog:
Aug 10 14:55:10 zoneminder zmcontrol[1636]: INF [Starting control server 1/FoscamFI8910W]
Aug 10 14:55:10 zoneminder zmcontrol[1640]: INF [Control server 1/FoscamFI8910W starting at 13/08/10 14:55:10]
Aug 10 14:55:13 zoneminder zmc_m1[1369]: INF [kamera-1: 1000 - Capturing at 15.15 fps]
Aug 10 14:55:17 zoneminder zma_m1[1424]: INF [kamera-1: 1000 - Processing at 15.38 fps]
Aug 10 14:55:18 zoneminder zmwatch[1396]: ERR [Shared data size conflict in shared_data for monitor kamera-1, expected 328, got 316]
Aug 10 14:55:20 zoneminder zmcontrol[1636]: FAT [Can't connect: No such file or directory]
Aug 10 14:55:20 zoneminder web_php[1044]: ERR [/usr/bin/zmcontrol.pl --autostop --command=moveConRight --id=1=>]
[Sat Aug 10 14:55:20 2013] [error] [client 192.168.0.201] ERR [/usr/bin/zmcontrol.pl --autostop --command=moveConRight --id=1=>], referer: [removed]/zm/?view=watch&mid=1
The foscam file is properly installed an registered as control:
root@zoneminder:/usr/share/perl5/ZoneMinder/Control# ls -alh
total 92K
drwxr-xr-x 2 root root 4.0K Aug 10 13:52 .
drwxr-xr-x 5 root root 4.0K Sep 23 2012 ..
-rw-r--r-- 1 root root 11K Jun 21 2011 AxisV2.pm
-rw-r--r-- 1 root root 5.9K Aug 10 13:52 FoscamFI8910W.pm
-rw-r--r-- 1 root root 5.2K Aug 26 2011 mjpgStreamer.pm
-rw-r--r-- 1 root root 5.2K Jun 21 2011 Ncs370.pm
-rw-r--r-- 1 root root 7.3K Jun 21 2011 PanasonicIP.pm
-rw-r--r-- 1 root root 19K Jun 21 2011 PelcoD.pm
-rw-r--r-- 1 root root 20K Jun 21 2011 Visca.pm
/usr/bin/zmcontrol.pl --autostop --command=moveConUpRight --id=1; echo $$
1544
Thanks, I really appreciate it!
Christian
