Page 1 of 1
FOSCAM FI-8608W H264 control script
Posted: Tue Aug 13, 2013 8:19 pm
by christophe_y2k
Hello, this script run under ZoneMinder V1.25 SVN release from "NexTimE" & "MasterTheKnifE"
All are describe in my other post for manually install the svn, its rapid and very easy
http://www.zoneminder.com/forums/viewto ... =9&t=21218
With this script for This FOSCAM FI-8608W you can move with pseudo speed control, you can use autostop
you can use preset, you can tweak brightness,contrast,hue,saturation
you can control IR LED ON/OFF/AUTO
All command are printed on the live video with the internal OSD of the camera.
Video was streamed via RTSP and FFmpeg with H264 codec at 640x480 resolution with good 25fps
# V1.0 ====================================================================================
# ZoneMinder FOSCAM version 1.0 API Control Protocol Module, $Date$, $Revision$
# Copyright (C) 2001-2008  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module FI8608W_Y2k.pm contains the implementation of API camera control
# For FOSCAM FI8608W PT Camera (This cam support only H264 streaming)
# V1.0 Le 13 AOUT 2013
# If you wan't to contact me i understand French and English, precise ZoneMinder in subject
# but i prefer via the ZoneMinder Forum
# My name is Christophe DAPREMONT my email is christophe_y2k@yahoo.fr
package ZoneMinder::Control::FI8608W_Y2k;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# FI8608W FOSCAM PT H264 Control Protocol
# with Firmware version V3.2.1.1.1-20120815 (latest at 13/08/2013)
# based with the latest doc from FOSCAM ( http://foscam.us/forum/cgi-api-sdk-for-mjpeg-h-264-camera-t2986.html )
# This IPCAM work under ZoneMinder V1.25 from alternative source of code
# from this svn at https://svn.unixmedia.net/public/zum/trunk/zum/
# Many Thanks to "MASTERTHEKNIFE" for the excellent speed optimisation ( http://www.zoneminder.com/forums/viewtopic.php?f=9&t=17652 )
# And to "NEXTIME" for the recent source update and incredible plugins ( http://www.zoneminder.com/forums/viewtopic.php?f=9&t=20587 )
# And all people helping ZoneMinder dev.
# -FUNCTIONALITIES:
# -Move camera in 8 direction with arrow, the speed of movement is function
#  of the position of your mouse on the arrow.
#  Extremity of arrow equal to fastest speed of movement
#  Close the base of arrow to lowest speed of movement
#  for diagonaly you can click before the begining of the arrow for low speed
#  In round center equal to stop to move and switch of latest OSD
# -You can clic directly on the image that equal to click on arrow (for the left there is a bug in zoneminder speed is inverted)
# -Zoom Tele switch ON InfraRed LED and stay to manual IR MODE
# -Zoom Wide switch OFF InfraRed LED and stay to manual IR MODE
# -Button WAKE switch to AUTO ON/OFF IR LED
# -Button RESET to setup image at initial value
# -8 Preset PTZ are implemented and functionnal
# -This Script use for login "admin" this hardcoded and your password must setup in "Control Device" section
# -This script is compatible with the basic authentification method used by mostly new camera based with hi3510 chipset
# -AutoStop function is active and you must set up value (in sec exemple 0.7) under AutoStop section
#  or you can set up to 0 for disable it (in this case you need to click to the circle center for stop)
# -"White In" to control Brightness, "auto" for restore the original value of Brightness
# -"White Out" to control Contrast, "man" for restore the original value of Contrast
# -"Iris Open" to control Saturation , "auto" for restore the original value of Saturation
# -"Iris Close" to control Hue , "man" for restore the original value of Hue
# -I use the OSD function of this cam for printing the command with the value
use Time::HiRes qw( usleep );
# Set $osd to "off" if you wan't disabled OSD i need to place this variable in another script because
# this script is reload at every command ,if i want the button on/off (Focus MAN) for OSD works...
my $osd = "on";
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    # I solve the authentification problem with recent Foscam
    # I use perl Basic Authentification method
    my $ua = LWP::UserAgent->new();
    my $req = HTTP::Request->new( GET =>"http://".$self->{Monitor}->{ControlAddress}."/web/cgi-bin/hi3510/".$cmd );
    $req->authorization_basic('admin', $self->{Monitor}->{ControlDevice} );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub reset
	my $self = shift;
	Debug( "Reset=Setup FI8608W" );
	if ( $osd eq "on" )
                 my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Color RESET";
    		 $self->sendCmd( $cmd );
	my $cmd = "param.cgi?cmd=setimageattr&-brightness=0";
	my $cmd = "param.cgi?cmd=setimageattr&-contrast=37";
	my $cmd = "param.cgi?cmd=setimageattr&-hue=255";
	my $cmd = "param.cgi?cmd=setimageattr&-saturation=94";
	my $cmd = "param.cgi?cmd=setinfra&-status=auto";
	my $cmd = "param.cgi?cmd=setimageattr&-scene=auto";
sub moveStop
	my $self = shift;
	Debug( "Move Stop" );
	my $cmd = "ptzctrl.cgi?-step=0&-act=stop";
        my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=0&-name=.";
sub autoStop
    my $self = shift;
    my $autostop = shift;
    if( $autostop )
       Debug( "Auto Stop" );
       usleep( $autostop );
sub moveConUp
    my $self = shift;
    my $params = shift;
    my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
    # Standardization for incorrect possible value in the database, and for realise at low and high speed an more precise moving
    if ( $tiltspeed > 100 ) {
			     $tiltspeed = 128;
    if ( $tiltspeed < 10 ) {
			    $tiltspeed = 1;
    Debug( "Move Up" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Move Up $tiltspeed";
    my $cmd = "ptzctrl.cgi?-step=0&-act=up";
    $self->autoStop( int(10000*$tiltspeed) );
sub moveConDown
    my $self = shift;
    my $params = shift;
			     $tiltspeed = 128;
		  	    $tiltspeed = 1;
    Debug( "Move Down" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Move Down $tiltspeed";
    my $cmd = "ptzctrl.cgi?-step=0&-act=down";
sub moveConLeft
    my $self = shift;
    my $params = shift;
    my $panspeed = $self->getParam( $params, 'panspeed' );
    if ( $panspeed > 100 ) {
			    $panspeed = 128;
    if ( $panspeed < 10 ) {
			   $panspeed = 1;
    # Algorithme pour inverser la table de valeur de la flèche gauche, (for invert the value) 63 ==> 1 et 1 ==> 63 ...
    $panspeed = abs($panspeed - 128) + 1;
    Debug( "Move Left" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Move Left $panspeed";
    my $cmd = "ptzctrl.cgi?-step=0&-act=left";
    $self->autoStop( int(10000*$panspeed) );
sub moveConRight
    my $self = shift;
    my $params = shift;
			    $panspeed = 128;
			   $panspeed = 1;
    Debug( "Move Right" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Move Right $panspeed";
    my $cmd = "ptzctrl.cgi?-step=0&-act=right";
sub moveConUpLeft
    my $self = shift;
    my $params = shift;
			     $tiltspeed = 128;
			    $tiltspeed = 1;
    # Standardization for incorrect value in the database
			    $panspeed = 128;
			   $panspeed = 1;
    Debug( "Move Con Up Left" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Up $tiltspeed Left $panspeed";
sub moveConUpRight
    my $self = shift;
    my $params = shift;
			     $tiltspeed = 128;
			    $tiltspeed = 1;
			    $panspeed = 128;
			   $panspeed = 1;
    Debug( "Move Con Up Right" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Up $tiltspeed Right $panspeed";
sub moveConDownLeft
    my $self = shift;
    my $params = shift;
	 		     $tiltspeed = 128;
			   $tiltspeed = 1;
			    $panspeed = 128;
			   $panspeed = 1;
    Debug( "Move Con Down Left" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Down $tiltspeed Left $panspeed";
sub moveConDownRight
    my $self = shift;
    my $params = shift;
	 		     $tiltspeed = 128;
			    $tiltspeed = 1;
			    $panspeed = 128;
			   $panspeed = 1;
    Debug( "Move Con Down Right" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Down $tiltspeed Right $panspeed";
sub zoomConTele
    my $self = shift;
    Debug( "Zoom-Tele=MANU IR LED ON" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Manual IR LED ON";
    my $cmd = "param.cgi?cmd=setinfra&-status=open";
sub zoomConWide
    my $self = shift;
    Debug( "Zoom-Wide=MANU IR LED OFF" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Manual IR LED OFF";
    my $cmd = "param.cgi?cmd=setinfra&-status=close";
sub wake
    my $self = shift;
    Debug( "Wake=AUTO IR LED" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Auto IR LED Mode";
sub whiteConIn
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'speed' );
    if ( $speed > 255 ) {
		         $speed = 255;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "White ConIn=brightness" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Brightness $speed";
    my $cmd = "param.cgi?cmd=setimageattr&-brightness=$speed";
    $self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
sub whiteConOut
    my $self = shift;
    my $params = shift;
		         $speed = 255;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "White ConOut=Contrast" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Contrast $speed";
    my $cmd = "param.cgi?cmd=setimageattr&-contrast=$speed";
sub whiteAuto
    my $self = shift;
    Debug( "White Auto=Brightness Reset" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Brightness Reset";
sub whiteMan
    my $self = shift;
    Debug( "White Manuel=Contrast Reset" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Contrast Reset";
sub irisConOpen
    my $self = shift;
    my $params = shift;
		         $speed = 255;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Iris ConOpen=Saturation" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Saturation $speed";
    my $cmd = "param.cgi?cmd=setimageattr&-saturation=$speed";
sub irisConClose
    my $self = shift;
    my $params = shift;
		         $speed = 255;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Iris ConClose=Hue" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Hue $speed";
    my $cmd = "param.cgi?cmd=setimageattr&-hue=$speed";
sub irisAuto
    my $self = shift;
    Debug( "Iris Auto=Saturation Reset" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Saturation Reset";
sub irisMan
    my $self = shift;
    Debug( "Iris Manuel=Hue Reset" );
    if ( $osd eq "on" )
         my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=Hue Reset";
sub presetSet
    my $self = shift;
    my $params = shift;
    if ( ( $preset >= 1 ) && ( $preset <= 8 ) ) {
					         if ( $osd eq "on" )
   					                 my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=PresetSet $preset";
						 my $preset = $preset - 1;
                                                 my $cmd = "preset.cgi?-act=set&-status=1&-number=$preset";
sub presetGoto
    my $self = shift;
    my $params = shift;
					         if ( $osd eq "on" )
					       		 my $cmd = "param.cgi?cmd=setoverlayattr&-region=1&-show=1&-name=PresetGoto $preset";
					         my $cmd = "preset.cgi?-act=goto&-number=$preset";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 FI-8608W
ZoneMinder::Database - Perl extension for FOSCAM FI-8608W by Christophe_Y2k
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
