IP cameras not all show picture in montage view
I have 20 plus cameras, but in montage view only max 9 give picture other are blanco. but when opening each one separate they work perfectly. I use Windows 7 x64 with Firefox 17esc8.. Anybody has a solution?
Re: IP cameras not all show picture in montage view
How do you fix this for Chromium? I could not find a similar config page.
With Chromium, I can see six out of eight cameras. The other cameras record properly and can be viewed individually, but they do not all appear on the montage screen.
