Cambozola problem in the reproduction of events
Hello, I have installed 1.25 ZM which I'm still setting up, and I have problems playing events, DO NOT I can play in the browser freezes text "Andy Wilcock Cambozola 0.92 to 0002 V 2010" and does nothing! , someone can help me!
I've changed Cambozola version, I put the 0.93, and has the same effect, NOT work!
I have tested it on different computers, tablets and different browsers, in all cases I get the same text and does not play anything.!
Live Monitoring is working properly.!
I have installed ubuntu ver. 12xxx
Thanks..!!
Antonio
Thanks..!!
Antonio
Re: Cambozola problem in the reproduction of events
Do you have Java installed on the machines you are trying to view the events on?
- knight-of-ni
In addition to verifying you have Java installed, verify OPT_CAMBOZOLA is enabled under options.
Also, what is PATH_CAMBOZOLA set to?
Hi Thanks!, For responding. I commented that java is installed on the machines ... and the path is as follows cambozola.jar PATH_CAMBOZOLA
- knight-of-ni
OK, so now find the cambozola.jar file on your filesystem. Where is it located?aodiaz wrote:Hi Thanks!, For responding. I commented that java is installed on the machines ... and the path is as follows cambozola.jar PATH_CAMBOZOLA
Hi!!, this is the path
/usr/share/zoneminder/cambozola.jar
I tell you that I have also installed the 160gb hard disk, where I keep events, idk if will have something to do ...
regards..
Antonio
regards..
Antonio
- knight-of-ni
Now check to make sure that your zoneminder webroot folder points to the same folder. It probably is, but let's make sure anyway. For an Ubuntu system, there is probably a config file under this folder /etc/apache2/conf.d. It might be called zonemidner.conf or zm.conf. Inside that file should be an Alias statement. Make sure it points to /usr/share/zoneminder/.
Also, do the following:
What happens?
cd /usr/share/zoneminder/
java -jar ./cambozola.jar
This is what contains my zoneminder.conf
Alias /zm /usr/share/zoneminder
<Directory /usr/share/zoneminder>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
and when I run the lines that sent me in console I get the following result:
root@srvcamaras:/home/usuario# cd /usr/share/zoneminder/
root@srvcamaras:/usr/share/zoneminder# java -jar ./cambozola.jar
El programa «java» puede encontrarse en los siguientes paquetes:
* default-jre
* gcj-4.6-jre-headless
* openjdk-6-jre-headless
* gcj-4.5-jre-headless
* openjdk-7-jre-headless
Intente: apt-get install <paquete seleccionado>
seems that the problem lies here!, but nose to do!!!
regards
Antonio
</IfModule>
</Directory>
* default-jre
regards
Antonio
- knight-of-ni
And I don't even have to know Spanish to see that output means you are missing Java.aodiaz wrote: root@srvcamaras:/home/usuario# cd /usr/share/zoneminder/
* default-jre
You need to install one of the suggested packages.
UPDATE: I took a closer look at those packages, and the first one looks to be the best fit. So do this:
sudo apt-get install default-jre
Once the update check turned to run the command line and throws me the following
Usage: WebCamURL [otherURLs] [-accessories=comma separated accessory list]
Current set of accessories are:
o ZoomIn - Zooms in to the image
o ZoomOut - Zooms out of the image
o Home - Shows all the image
o Pan - Pan around a zoomed-in image
o ChangeStream - Swap to a different stream (if > 1 listed)
o Info - Displays information about the stream
o WWWHelp - Displays a web page showing help
-debug Write debug information
-width={width} Sets the width of the application
-height={height} Sets the height of the application
-noaccessories Will not display any accessories
-accessories=none Will not display any accessories
-accessories=default Will display the default set of accessories
-accessorystyle={see below} Defines how the accessories will appear on top-left
indent Will squeeze the image [default]
overlay Will overlay the accessories onto the image
always Always display the accessories (overlaid)
-retries={num} The number of retries (default = 1)
-delay={num} The number of milliseconds between retries
-failureimage={url} Image to display if failure to connect
-backgroundColor=#RRGGBB Background Color in hex - e.g. #FF0000 for red
-textColor=#RRGGBB Text Color in hex - e.g. #FFFFFF for white
-userAgent={useragent} Sets the user-agent string, which will be used in the HTTP-request (f.e. 'Mozilla/5.0'
-profile={Camera Profile} Choose profile for camera
-watermark={see below} List of watermarks, separated by '|'
imageURL|corner|linkURL Watermark information, separated by '|'
regards!
regards!
- knight-of-ni
Yep, that's the same ouput I get. Zoneminder should work now.
Hello, NO NO, does not work, I tried it on 3 pc and nothing, delete cookies, temporary, etc. and does the same ...
It could be problem picture in some folder??, Another testing could be done to find the problem?
regards!
regards!
- knight-of-ni
What do your log files say at the moment you try to play back a recorded event?
In principle there are many errors like this ..!
2013-08-20 19:38:05.759080 zmwatch 4187 ERR Shared data size conflict in shared_data for monitor Mini, expected 328, got 316 zmwatch.pl
and also how these
2013-08-20 19:42:12.493462 zmc_m1 4141 WAR Corrupt JPEG data: 1 extraneous bytes before marker 0xd9 zm_jpeg.cpp 63
other
2013-08-20 20:03:41.355007 web_php 4608 ERR socket_sendto( /tmp/zm/zms-998504s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2322
but nose as a filter properly when I try to play an event.!
achieves lower the log, I attached!
regards!
and also how these
other
regards!
log...
2013-08-20 20:10:57.274222 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:58.102721 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:58.481876 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:10:58.774493 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:58.979134 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:59.088331 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:59.270274 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:10:59.356895 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:59.470673 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:10:59.957569 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:00.051555 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:00.145273 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:00.251809 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.251248 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.461054 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.553460 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.649779 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.866731 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:01.953233 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:02.459508 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:02.566380 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:02.567850 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:02.568840 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:02.570140 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:02.575670 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:02.930773 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:03.240480 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:03.835247 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:04.138353 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:04.246510 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:04.326332 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:04.522383 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:04.838896 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:05.530932 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:05.622515 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:06.690474 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:06.792455 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:07.521349 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:07.925858 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:08.177356 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:08.382748 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:09.506751 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:11.071553 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:11.570418 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:11.678786 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:11.895031 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:12.577720 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:12.590790 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:12.595070 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:12.603120 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:12.608070 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:13.855034 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:14.253030 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:14.547575 zmc_m2[4149].INF-zm_monitor.cpp/2598 [Vilar: 36000 - Capturing at 17.86 fps]
2013-08-20 20:11:14.586851 zmc_dvideo1[4159].INF-zm_monitor.cpp/2598 [Lavadero: 46000 - Capturing at 19.61 fps]
2013-08-20 20:11:15.850968 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:16.337356 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:16.824050 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:17.053266 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:18.034648 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:18.128233 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:18.737351 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:20.603936 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:21.122349 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:21.605880 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:22.437733 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:22.613260 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:22.615690 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:22.618700 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:22.621390 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:22.634580 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:22.909816 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:25.124007 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:26.365425 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:27.002318 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:27.385891 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:27.445660 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:27.818793 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:27.982974 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:28.645857 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:29.156822 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:30.765992 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:30.876075 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:31.381312 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:31.933499 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:32.626008 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:32.646500 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:32.647910 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:32.649220 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:32.650570 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:32.658440 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:32.844470 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:33.202472 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:33.346498 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:33.709862 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:33.934005 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:34.183097 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:37.097928 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:37.643001 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:38.099855 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:38.476984 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:38.556993 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:38.842960 zmc_dvideo2[4171].INF-zm_monitor.cpp/2598 [Mini: 48000 - Capturing at 19.23 fps]
2013-08-20 20:11:39.019997 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:40.051118 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:40.775365 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:41.095437 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:41.196904 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:41.483443 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:42.687640 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:42.722100 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:42.734810 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:42.763180 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:42.771660 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:44.315082 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:44.765502 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:46.135454 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:46.838199 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:47.625995 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:48.056247 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:48.211708 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:48.323335 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:48.736844 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:49.651254 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:50.284713 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:50.411666 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:50.442282 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:50.592818 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:51.727014 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:52.084383 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:52.795070 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:11:52.809170 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:52.818950 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:11:52.835170 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:11:52.843140 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:11:52.990038 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:53.688252 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:54.303768 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:11:54.712176 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:55.263167 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:55.457557 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:55.597383 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:56.277786 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:56.355955 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:56.675388 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:57.202753 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:59.479722 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:11:59.919710 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:00.335767 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:00.542581 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:00.664687 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:00.806889 zms[4767].INF-zm_user.cpp/231 [Authenticated user 'admin']
2013-08-20 20:12:01.055164 zms[4767].ERR-zm_event.cpp/1225 [Can't open /usr/share/zoneminder//media/hd160gb/events/3/13/08/20/19/53/05/001-capture.jpg: No such file or directory]
2013-08-20 20:12:01.367041 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:01.948538 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:02.878370 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:12:02.888780 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:12:02.900880 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:12:02.916970 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:12:02.924980 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:12:03.255853 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:04.125666 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:04.465253 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:04.760323 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:04.807841 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:04.944689 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:05.838323 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:07.153139 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:12:07.293028 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:07.475648 zma_m2[4153].INF-zm_monitor.cpp/1055 [Vilar: 24000 - Processing at 13.33 fps]
2013-08-20 20:12:07.540408 zmc_dvideo1[4159].INF-zm_monitor.cpp/2598 [Lavadero: 47000 - Capturing at 18.87 fps]
2013-08-20 20:12:08.092910 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:08.989084 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:09.623680 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:10.051747 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:10.407609 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:11.057749 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:12:11.517399 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:11.753212 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:12.068302 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:12.942730 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Tanque, expected 328, got 316]
2013-08-20 20:12:12.959080 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:12:12.964580 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Vilar, expected 328, got 316]
2013-08-20 20:12:12.971810 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Lavadero, expected 328, got 316]
2013-08-20 20:12:12.998090 zmwatch[4187].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Mini, expected 328, got 316]
2013-08-20 20:12:13.509495 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:14.048319 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:14.175000 zmc_m2[4149].INF-zm_monitor.cpp/2598 [Vilar: 37000 - Capturing at 16.67 fps]
2013-08-20 20:12:15.846371 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:16.684718 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:16.872482 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:12:18.788674 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
2013-08-20 20:12:19.176712 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
2013-08-20 20:12:19.298470 zmc_m1[4141].WAR-zm_jpeg.cpp/63 [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
