Page 1 of 1
FOSCAM FI9821W H264 Control Script
Posted: Mon Aug 19, 2013 7:22 pm
by christophe_y2k
Hello, this script run under ZoneMinder V1.25 SVN release from "NexTimE" & "MasterTheKnifE"
All are describe in my other post for manually install the svn, its rapid and very easy
http://www.zoneminder.com/forums/viewto ... =9&t=21218
With this script for This FOSCAM FI-9821W you can move with pseudo speed control, you can use autostop
you can use preset, you can tweak brightness,contrast,hue,saturation
you can control IR LED ON/OFF/AUTO
All command are printed on the live video with the internal OSD of the camera.
Video was streamed via RTSP and FFmpeg with H264 codec at 1280x720 resolution with 10 to 20fps
This camera is always bugged (all foscam product are) she reboot itself
# ZoneMinder FOSCAM version 1.0 API Control Protocol Module, $Date$, $Revision$
# Copyright (C) 2001-2008  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module FI8620_Y2k.pm contains the implementation of API camera control
# For FOSCAM FI8620 Dome PTZ Camera (This cam support only H264 streaming)
# V1.0  Le 09 AOUT 2013 - production usable for the script but not for the camera "reboot itself"
# If you wan't to contact me i understand French and English, precise ZoneMinder in subject
# My name is Christophe DAPREMONT my email is christophe_y2k@yahoo.fr
package ZoneMinder::Control::FI9821W_Y2k;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# FI9821 FOSCAM PT H264 Control Protocol
# with Firmware version V1.2.1.1 (latest at 09/08/2013)
# based with the latest buggy CGI doc from FOSCAM ( http://foscam.us/forum/cgi-sdk-for-hd-camera-t6045.html )
# This IPCAM work under ZoneMinder V1.25 from alternative source of code
# from this svn at https://svn.unixmedia.net/public/zum/trunk/zum/
# Many Thanks to "MASTERTHEKNIFE" for the excellent speed optimisation ( http://www.zoneminder.com/forums/viewtopic.php?f=9&t=17652 )
# And to "NEXTIME" for the recent source update and incredible plugins ( http://www.zoneminder.com/forums/viewtopic.php?f=9&t=20587 )
# And all people helping ZoneMinder dev.
# -FUNCTION: display on OSD
# speed is progressive in function of where you click on arrow ========>
#                                                    speed low=/       \=speed high
use Time::HiRes qw( usleep );
# Set $osd to "off" if you wan't disabled OSD i need to place this variable in another script because
# this script is reload at every command ,if i want the button on/off (Focus MAN) for OSD works...
my $osd = "on";
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    my $temps = time();
    my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/cgi-bin/CGIProxy.fcgi?usr%3Dadmin%26pwd%3D".$self->{Monitor}->{ControlDevice}."%26cmd%3D".$cmd."%26".$temps );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub reset
{	my $self = shift;
	Debug ( "Reset = setup camera FI9821W" );
	# Setup OSD
	my $cmd = "setOSDSetting%26isEnableTimeStamp%3D0%26isEnableDevName%3D1%26dispPos%3D0%26isEnabledOSDMask%3D0";
	$self->sendCmd( $cmd );
	# Setup For Stream=0 Resolution=720p Bandwith=4M FPS=30 KeyFrameInterval/GOP=100 VBR=ON
	my $cmd = "setVideoStreamParam%26streamType%3D0%26resolution%3D0%26bitRate%3D4194304%26frameRate%3D30%26GOP%3D100%26isVBR%3D1";
	# Setup For Infrared AUTO
	my $cmd = "setInfraLedConfig%26Mode%3D1";
	# Reset image settings
	my $cmd = "resetImageSetting";
sub moveStop
	my $self = shift;
	Debug( "Move Stop" );
        my $cmd = "ptzStopRun";
        my $cmd = "setDevName%26devName%3D.";
	my $cmd = "setOSDSetting%26isEnableDevName%3D1";
sub autoStop
    my $self = shift;
    my $autostop = shift;
    if( $autostop )
       Debug( "Auto Stop" );
       usleep( $autostop );
sub moveConUp
    my $self = shift;
    my $params = shift;
    my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
    # speed inverter 4-->0 , 3-->1 , 2-->2 , 1-->3 , 0-->4
    $tiltspeed = abs($tiltspeed - 4);
    # Normalisation en cas de valeur erronée dans la base de données
    if ( $tiltspeed > 4 ) {
			   $tiltspeed = 4;
    if ( $tiltspeed < 0 ) {
			   $tiltspeed = 0;
    Debug( "Move Up" );
    if ( $osd eq "on" )
	 my $cmd = "setDevName%26devName%3DMove Up $tiltspeed";
    my $cmd = "setPTZSpeed%26speed%3D$tiltspeed";
    my $cmd = "ptzMoveUp";
    $self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
sub moveConDown
    my $self = shift;
    my $params = shift;
    # Normalization
			   $tiltspeed = 4;
		  	   $tiltspeed = 0;
    Debug( "Move Down" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Down $tiltspeed";
    my $cmd = "ptzMoveDown";
sub moveConLeft
    my $self = shift;
    my $params = shift;
    my $panspeed = $self->getParam( $params, 'panspeed' );
    if ( $panspeed > 4 ) {
			   $panspeed = 4;
    if ( $panspeed < 0 ) {
			  $panspeed = 0;
    Debug( "Move Left" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Left $panspeed";
    my $cmd = "setPTZSpeed%26speed%3D$panspeed";
    my $cmd = "ptzMoveLeft";
sub moveConRight
    my $self = shift;
    my $params = shift;
    $panspeed = abs($panspeed - 4);
		          $panspeed = 4;
			  $panspeed = 0;
    Debug( "Move Right" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Right $panspeed";
    my $cmd = "ptzMoveRight";
sub moveConUpLeft
    my $self = shift;
    my $params = shift;
			   $tiltspeed = 4;
			   $tiltspeed = 0;
        Debug( "Move Con Up Left" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Up Left $tiltspeed";
    my $cmd = "ptzMoveTopLeft";
sub moveConUpRight
    my $self = shift;
    my $params = shift;
			   $tiltspeed = 4;
			   $tiltspeed = 0;
    Debug( "Move Con Up Right" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Up Right $tiltspeed";
    my $cmd = "ptzMoveTopRight";
sub moveConDownLeft
    my $self = shift;
    my $params = shift;
			   $tiltspeed = 4;
			   $tiltspeed = 0;
    Debug( "Move Con Down Left" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DMove Down Left $tiltspeed";
    my $cmd = "ptzMoveBottomLeft";
sub moveConDownRight
    my $self = shift;
    my $params = shift;
			   $tiltspeed = 4;
			   $tiltspeed = 0;
    Debug( "Move Con Down Right" );
    if ( $osd eq "on" )
	 my $cmd = "setDevName%26devName%3DMove Down Right $tiltspeed";
    my $cmd = "ptzMoveBottomRight";
sub zoomConTele
    my $self = shift;
    Debug( "Zoom-Tele=MANU IR LED ON" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DManual IR LED Switch ON";
    my $cmd = "setInfraLedConfig%26mode%3D1";
    my $cmd = "openInfraLed";
sub zoomConWide
    my $self = shift;
    Debug( "Zoom-Wide=MANU IR LED OFF" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DManual IR LED Switch OFF";
    my $cmd = "closeInfraLed";
sub wake
    my $self = shift;
    Debug( "Wake=AUTO IR LED" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DAuto IR LED Mode";
    my $cmd = "setInfraLedConfig%26mode%3D0";
sub focusConNear
    my $self = shift;
    my $params = shift;
    my $speed = $self->getParam( $params, 'speed' );
    if ( $speed > 100 ) {
	 	         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Focus Near=Sharpness" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DSharpness $speed";
    my $cmd = "setSharpness%26sharpness%3D$speed";
    # La variable speed ne fonctionne pas en paramètre du focus, alors je l'utilise pour définir la durée de la commande
    # le résulat est identique
sub focusConFar
    my $self = shift;
    my $params = shift;
		         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Focus Far" );
    if ( $osd eq "on" )
    # La variable speed ne fonctionne pas en paramètre du focus alors je l'utilise pour définir la durée de la commande
sub focusAuto
    my $self = shift;
    Debug( "Focus Auto=Reset Sharpness" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DReset Sharpness";
    my $cmd = "setSharpness%26sharpness%3D10";
sub focusMan
    my $self = shift;
    Debug( "Focus Manu=Reset Sharpness" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DFOSCAM FI9821W Script V1.0 By Christophe_y2k";
sub whiteConIn
    my $self = shift;
    my $params = shift;
	 	         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "White ConIn=brightness" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DBrightness $speed";
    my $cmd = "setBrightness%26brightness%3D$speed";
sub whiteConOut
    my $self = shift;
    my $params = shift;
	 	         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "White ConOut=Contrast" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DContrast $speed";
    my $cmd = "setContrast%26constrast%3D$speed";
sub whiteAuto
    my $self = shift;
    Debug( "White Auto=Brightness Reset" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DBrightness Reset";
    my $cmd = "setBrightness%26brightness%3D50";
sub whiteMan
    my $self = shift;
    Debug( "White Manuel=Contrast Reset" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DContrast Reset";
    my $cmd = "setContrast%26constrast%3D44";
sub irisConOpen
    my $self = shift;
    my $params = shift;
		         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Iris ConOpen=Saturation" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DSaturation $speed";
    my $cmd = "setSaturation%26saturation%3D$speed";
sub irisConClose
    my $self = shift;
    my $params = shift;
		         $speed = 100;
    if ( $speed < 0 ) {
		       $speed = 0;
    Debug( "Iris ConClose=Hue" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DHue $speed";
    my $cmd = "setHue%26hue%3D$speed";
sub irisAuto
    my $self = shift;
    Debug( "Iris Auto=Saturation Reset" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DSaturation Reset";
    my $cmd = "setSaturation%26saturation%3D30";
sub irisMan
    my $self = shift;
    Debug( "Iris Manuel=Hue Reset" );
    if ( $osd eq "on" )
         my $cmd = "setDevName%26devName%3DHue Reset";
    my $cmd = "setHue%26hue%3D6";
sub presetSet
    my $self = shift;
    my $params = shift;
    if ( ( $preset >= 1 ) && ( $preset <= 16 ) ) {
    						  Debug( "Clear Preset $preset" );
    						  my $cmd = "ptzDeletePresetPoint%26name%3D$preset";
					          if ( $osd eq "on" )
   					                  my $cmd = "setDevName%26devName%3DSet Preset $preset";
                                                  my $cmd = "ptzAddPresetPoint%26name%3D$preset";
sub presetGoto
    my $self = shift;
    my $params = shift;
					         if ( $osd eq "on" )
							 my $cmd = "setDevName%26devName%3DGoto Preset $preset";
						 my $cmd = "setPTZSpeed%26speed%3D0";
					         my $cmd = "ptzGotoPresetPoint%26name%3D$preset";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 FI9821W
ZoneMinder::Database - Perl extension for FOSCAM FI9821W
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
Re: FOSCAM FI9821W H264 Control Script
Posted: Wed Feb 19, 2014 7:46 am
by mariusz0709
Hi
Motion tracking is working correctly on this foscam?
Posted: Wed Feb 19, 2014 10:15 am
by christophe_y2k
Hello, i never seen motion tracking working ...
Now i use the new version of zoneminder V1.26.5 on my Gentoo from GitHub and i need to retest all PTZ script...
Posted: Thu Feb 20, 2014 11:09 am
by mariusz0709
I use V1.26.5 and there is a bug. When I use ffmpeg, when I use ffmpeg, I can not turn the PTZ on. Drop-down list of file control does not work. So I can't turn on PTZ.
