Trendnet TV-IP651W(I) Control script
Posted: Wed Sep 04, 2013 8:20 pm
I'm a complete newb when it comes to zonemaster controls, so I imagine there is room to improve on this script. Nevertheless, here is version 1.0 which works.
If you're on ubuntu, drop this script in /usr/share/perl5/ZoneMinder/Control and call it TV-IP651.pm . If you're on another distro, find the file called "AxisV2.pm" and stick it in the same directory.
For those keeping track, I started with the TV-IP400 script and a network capture to figure out where it was going wrong when trying to control the TV-IP651. Turns out the user-agent was the key!
# =========================================================================r
# ZoneMinder Trendnet TV-IP651W(I) IP Control Protocol Module, $Date: $, $Revision: $
# Copyright (C) 2013 Vincent G
# Based on TVIP400 by Peter Hulst & Philip Coombes (thanks for the huge head start, guys!)
# For Zoneminder 1.25
# Under control capability:
# * Main: name it (suggest TVIP651), type is remote, protocol is TVIP651
# * Move: Can move, can move diagonally, can move mapped, can move relative
# * Pan: Can pan, min pan step 1, max pan step 10
# * Tilt: Can tilt, min tilt step 1, max tilt step 10
# * Presets: Has presets, num presets 24, has home preset
# Under control tab in the monitor itself:
# * Controllable (duh)
# * Control type is the name you gave it in the control capability menu
# * Control device is the username you use to authenticate to the camera (MUST MATCH the control address username!)
# * Control address is the camera's ip address, or if authenticating, user:pass@ip.address
# This module contains the implementation of the Trendnet TV-IP651W(I) IP camera control
# protocol.
package ZoneMinder::Control::TVIP651;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Trendnet TV-IP651 Control Protocol
# changed per advice found on http://foscam.us/forum/zoneminder-1-25-0-with-foscam-fi8918w-control-problems-t3891.html .
#use ZoneMinder::Debug qw(:all);
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} ); }
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
# I'm not setting the user agent to be a jerk, the camera ACTUALLY CHECKS it! If it doesn't match the authentication username, everything fails!
$self->{ua}->agent( "USER".$self->{Monitor}->{ControlDevice});
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
my $req = HTTP::Request->new( POST=>"http://".$self->{Monitor}->{ControlAddress}."/PANTILTCONTROL.CGI" );
$req->content($cmd);
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub move
my $self = shift;
my $dir = shift;
my $panSteps = shift;
my $tiltSteps = shift;
my $cmd = "PanSingleMoveDegree=$panSteps&TiltSingleMoveDegree=$tiltSteps&PanTiltSingleMove=$dir";
$self->sendCmd( $cmd );
sub moveRelUpLeft
my $self = shift;
Debug( "Move Up Left" );
$self->move( 0, 1, 1 );
sub moveRelUp
my $self = shift;
Debug( "Move Up" );
$self->move( 1, 1, 1 );
sub moveRelUpRight
my $self = shift;
Debug( "Move Up" ); $self->move( 2, 1, 1 );
sub moveRelLeft
my $self = shift;
Debug( "Move Left" );
$self->move( 3, 1, 1 );
sub moveRelRight
my $self = shift;
Debug( "Move Right" );
$self->move( 5, 1, 1 );
sub moveRelDownLeft
my $self = shift;
Debug( "Move Down" );
$self->move( 6, 1, 1 );
sub moveRelDown
my $self = shift;
$self->move( 7, 1, 1 );
sub moveRelDownRight
my $self = shift;
$self->move( 8, 1, 1 );
# moves the camera to center on the point that the user clicked on in the video image.
# This isn't extremely accurate but good enough for most purposes
sub moveMap
# if the camera moves too much or too little, try increasing or decreasing this value
my $f = 11;
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
my $hor = $xcoord * 100 / $self->{Monitor}->{Width};
my $ver = $ycoord * 100 / $self->{Monitor}->{Height};
my $direction;
my $horSteps;
my $verSteps;
if ($hor < 50 && $ver < 50) {
# up left
$horSteps = (50 - $hor) / $f;
$verSteps = (50 - $ver) / $f;
$direction = 0;
} elsif ($hor >= 50 && $ver < 50) {
# up right
$horSteps = ($hor - 50) / $f;
$direction = 2;
} elsif ($hor < 50 && $ver >= 50) {
# down left
$verSteps = ($ver - 50) / $f;
$direction = 6;
} elsif ($hor >= 50 && $ver >= 50) {
# down right
$direction = 8;
my $v = int($verSteps + .5);
my $h = int($horSteps + .5);
Debug( "Move Map to $xcoord,$ycoord, hor=$h, ver=$v with direction $direction" );
$self->move( $direction, $h, $v );
# this clear function works, but should probably be disabled because
# it isn't possible to set presets yet.
sub presetClear
my $self = shift; my $params = shift;
Debug( "Clear Preset $preset" );
my $cmd = "ClearPosition=$preset";
# not working yet
sub presetSet
my $self = shift;
my $params = shift;
# TODO need to first get current position $horPos and $verPos
#my $cmd = "PanTiltHorizontal=$horPos&PanTiltVertical=$verPos&SetName=$preset&SetPosition=$preset";
#$self->sendCmd( $cmd );
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "PanTiltPresetPositionMove=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "PanTiltSingleMove=4";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for Trendnet TVIP651
=head1 SYNOPSIS
use ZoneMinder::Database;
stuff this in /usr/share/perl5/ZoneMinder/Control , then eat a sandwich
=head1 DESCRIPTION
Stub documentation for Trendnet TVIP651, created by Vince.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Read the comments at the beginning of this file to see the usage for zoneminder 1.25.0
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
Vincent G, I'd rather you not email me.
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2005 by Philip Coombes
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
