Page 1 of 1
Opensuse 12.3 and newest version
Posted: Sat Oct 12, 2013 9:29 pm
by Stuggy
I am running v1.25 I think and have been getting the popups about a new version that is available. However, I haven't been able to update. yast etc doesn't show a new version available. Is an Opensuse version available somewhere?
Re: Opensuse 12.3 and newest version
Posted: Wed Oct 16, 2013 12:13 am
by knight-of-ni
Yast isn't going to show an upgrade until OpenSuse adds it to their repo. This is a question for the OpenSuse developers to answer as it is entirely up to them.
You or some other OpenSuse enthusiast could roll your own custom rpm however...
Posted: Wed Oct 16, 2013 9:58 pm
by heroldssalads
there is a special repo of opensuse zoneminder builds for opensuse. Check here for the additional repos
http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE
Posted: Thu Oct 17, 2013 6:43 am
by Stuggy
Yep I've seen the wiki links but I don't think there is a latest build. I also used the MP version. I am used to coding in Windows so in theory I might be able to build a SUSE version but to be honest I'm still working out how it all works.
Posted: Fri Oct 18, 2013 9:10 pm
by heroldssalads
the newest version of opensuse (13.1) should be arriving in november. the latest version of zoneminder should be available then.
Posted: Sat Nov 16, 2013 5:36 pm
by monex
I just updated the repositories with the new packages for ZoneMinder 1.26.4. I'm sorry for for the late packaging but I missed the new version somehow
If you encounter any problems report, especially when upgrading, report them in the forum, I try to watch out the forums more often the next weeks
Btw. don't expect packages for 13.1 before December. It will take a while to install 13.1 and prepare the build environment to build the packages, impatient people can use my openSUSE build service repository at
http://download.opensuse.org/repositori ... nSUSE_13.1 but packages here are build without ffmpeg support.
Have a lot of fun
Dirk
Posted: Sat Nov 16, 2013 5:45 pm
by xmasin
Is it possible to build Zoneminder with ffmpeg support? I have bought new Vivotek IP camera and I'd like to try this camera with Zoneminder.
Posted: Sun Nov 17, 2013 5:20 pm
by monex
the packages build against ffmpeg are marked with "MP" in the package name, simply install ZoneMinder-MP from the repositories mentioned in the wiki page
http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE.
Due to legal issues it is not allowed to build packages with ffmpeg support in the openSUSE build service. For this reason the best choice is to use the repositories from the wiki page.
I just mentioned the link to my build service repository because it takes a while to setup the build environment for openSUSE 13.1. When this is done I will publish a version with and without ffmpeg support as usual.
Have a lot of fun
Dirk
Posted: Sat Dec 07, 2013 8:57 pm
by xmasin
I just have updated my server with OpenSuSE 13.1 and Zoneminder with ffmpeg support from
http://www.liquid-co.de/pub/suse/repositories/13.1/ to latest version and I have several problems:
1) I'm able to setup local and remote camera, but several items in listbox are missing or not visible (for example Source type local/remote) in Czech language in English language are visible.
2) When I start recording (record or mocord) I have a lot of mesages in log with this message:Can't insert frame: Out of range value for column 'Score' at row 1
3) I'am not able to stop zoneminder using web frontend.
Any suggestion how to fix this problems?
Posted: Sun Dec 08, 2013 12:31 pm
by xmasin
after hours trying to get latest version of Zoneminder working I found the reason for error message in log. In Frames table is row Score unsigned smallint data type, but after a few frames after starting capture is score -1 populated from Zoneminder to database, so I have changed data type tu signed smallint and now is Zoneminder working, but other issues are still there.
Radek Masin
Posted: Tue Dec 31, 2013 5:08 pm
by monex
you have to set the correct sql_mode for zonemidner in /etc/my.cnf as described here:
http://www.zoneminder.com/wiki/index.ph ... and_Apache
After that restart mysql.
Otherwise ZM won't run as expected. I don't know why they've changed the default sql mode
Have a lot of fun
Dirk
Posted: Fri Jan 10, 2014 9:10 am
by xmasin
in my config file for mysql is sql mode set as in previous versions:
sql_mode=NO_ENGINE_SUBSTITUTION,STRICT_TRANS_TABLES
Regards
Radek Masin
