Ubuntu 12.04 Zoneminder upgrade from 1.25.0 to 1.26.4
Posted: Wed Oct 16, 2013 2:44 pm
First, thanks to all of you who discovered the bits and pieces to make this work! My process is a bit cumbersome but it worked!!!
Zoneminder 1.25.0 was installed from my write up titled:
Ubuntu Server 12.04 64-bit with Zoneminder 1.25.0 the easy way
I then added the Launchpad repository:
apt-get install python-software-properties
add-apt-repository ppa:iconnor/zoneminder
apt-get update
Install the new Zoneminder
apt-get dist-upgrade
When you get to the first prompt asking what you want to do with the Zoneminder configuration file, STOP for a minute. You will need to create a symbolic link called db in:
/build/buildd/zoneminder-1.26.4 pointing to /usr/share/zoneminder/db
I did this by using Webmin file manager. I know you can open another terminal session to do this but I do what is comfortable for me.
Now that you have created a symbolic link continuue at the first terminal. I selected "Y" to overwrite the configuration file. You will have several other prompts asking if you want to convert the database. I chose to convert it and it worked for me!
When finished open:
nano /etc/init.d/zoneminder
Add above "zmfix -a" sleep 15
Ctrl+o Enter to save
CTRL+x to exit
I did notice that I had to switch my camera from Greyscale to color. Otherwise it all worked! Would be appreciative for comments to improve this. bb
apt-get update
When finished open:
CTRL+x to exit
