Asante Voyager I (Smartbot) IP camera
Posted: Thu Oct 17, 2013 3:15 am
I've gotten this camera to work in ZM using simple http as follows:
Source Type: Remote
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: <username>:<password>@<ipaddress>
Remote Host Port: 80
Remote Host Path: /image.cgi?camera=1&type=motion
Remote Image Colors: 24 bit
Capture Width: 1280
Capture Height: 1024
I get about 6fps using this method although the camera itself is set for 15fps. I'm assuming the Asante Voyager II camera would also work using the same settings.
I cannot get rtsp to work in ZM no matter what I try even tho I can access the camera's RTSP streams just fine from VLC Media Player using either of the URL formats:
mjpeg:
mpeg4:
I've tried using Remote Protocol=RTSP and all the different RTSP methods. However when I do this, I get no video in ZM and I see the following error in the ZM logs:
I've also tried using Source Type=Ffmpeg using the above URLs but again it does not work even though I've enabled and set the correct path to ffmpeg (avconv) in the ZM settings.
Source Type: Remote
Capture Width: 1280
mjpeg:
rtsp://user:password@ipaddress:554/cam1/mjpeg
rtsp://user:password@ipaddress:554/cam1/mpeg4
2013-10-16 20:31:18.153107 zmc_m2 29383 ERR Unsupported media type 'event' in SDP media attribute 'event 0 RTP/AVP 69' zm_rtsp.cpp 314
