Monitor won't start recording
ThomasNovin
Post by ThomasNovin »
Hello
Using v1.26.4 on Ubuntu with my Level One FCS 5030 camera.
Only one monitor / one zone. Monitor set to modetect.
When there is movement i my zone, alarm is not triggered.
Attaching a screenshot of my zone. Is there anything else I need to configure?
Btw, if I do force alarm it records fine.
chippy99
Re: Monitor won't start recording
Post by chippy99 »
Have you tried setting the min pixel threshold to a lower figure? You currently have it set at 20, try setting it to 10 or even lower if still no motion detection.
ThomasNovin
I doubt it will help but I will try. I stood in the middle of the camera view and waved so that should have been plenty over the already defined threshold.
