# zmupdate.pl
Initiating database upgrade to version 1.26.4 from version 1.25.0
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop :
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : n
Upgrading database to version 1.26.4
Loading config from DB
No option 'ZM_LOCAL_BGR_INVERT' found, removing at /usr/lib/perl5/site_perl/5.16.0/ZoneMinder/ConfigAdmin.pm line 89, <STDIN> line 2.
No option 'ZM_Y_IMAGE_DELTAS' found, removing at /usr/lib/perl5/site_perl/5.16.0/ZoneMinder/ConfigAdmin.pm line 89, <STDIN> line 2.
No option 'ZM_V4L2_CAPTURE_FIELDS' found, removing at /usr/lib/perl5/site_perl/5.16.0/ZoneMinder/ConfigAdmin.pm line 89, <STDIN> line 2.
Saving config to DB
DBD::mysql::db do failed: ALTER command denied to user 'zmuser'@'localhost' for table 'Monitors' at /usr/local/bin/zmupdate.pl line 1010, <STDIN> line 2.
DBD::mysql::db do failed: ALTER command denied to user 'zmuser'@'localhost' for table 'Monitors' at /usr/local/bin/zmupdate.pl line 1013, <STDIN> line 2.
Previous versions of ZoneMinder used the MyISAM database engine.
However, the recommended database engine is InnoDB.
Hint: InnoDB tables are much less likely to be corrupted during an unclean shutdown.
Press 'y' to convert your tables to InnoDB or 'n' to skip : n
Upgrading DB to 1.26.1 from 1.26.0
Database successfully upgraded from version 1.26.1.
Upgrading DB to 1.26.2 from 1.26.0
Database successfully upgraded from version 1.26.2.
Upgrading DB to 1.26.3 from 1.26.0
Database successfully upgraded from version 1.26.3.
Database upgrade to version 1.26.4 successful.
ALTER TABLE `Monitors` ADD `Colours` TINYINT UNSIGNED NOT NULL DEFAULT '1' AFTER `Height`;
ALTER TABLE `Monitors` ADD `Deinterlacing` INT UNSIGNED NOT NULL DEFAULT '0' AFTER `Orientation`;
