Latest ZM on ubuntu 13.10 server
digitel
Post by digitel »
Hi
I tried to install ZM on Ubuntu 13.10 server (fresh install of both)
I followed these guides :
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
http://www.zoneminder.com/wiki/index.ph ... on_changes
ZM installs but it is the 1.25.0 version
I'm able to setup a monitor for testing purpose but first I have a java exception when going to see that camera window (filenotfound)
It seems there is no link to cgi-bin directory during installation , i solved adding
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
to /etc/apache2/sites-available/000-default.conf (a2ensite then apache reload)
Why is this issue after installation ???
Is this the right way to solve the issue ??
Now when I try to access camera window i have another java exception (http error 403) because I have no permission to access /cgi-bin/ directory on the system
Are these known issues ???
How can I solve them ??
I followed carely step-by-step the guides,
Any hint please ???
Thank you
digitel
Re: Latest ZM on ubuntu 13.10 server
Post by digitel »
A note adding PPA repository on Ubuntu 13.10 server , before to start ZM installation
After :
apt-get install python-software-properties
add-apt-repository ppa:iconnor/zoneminder
at the end of apt-get update i get:
http ://ppa launchpad net/iconnor/zoneminder/ubuntu/dists/saucy/main/binary-amd64/Packages 404 Not Found
http ://ppa launchpad net/iconnor/zoneminder/ubuntu/dists/saucy/main/binary-i386/Packages 404 Not Found
Isn't that repository ready yet for saucy 13.10 ???
Any hint ??
digitel
Post by digitel »
Sorry for the self-reply, but no one experienced problems on Ubuntu Server 13.10 ??
Or no one using it yet ??
Sorry for the problems. Ubuntu 13.10 has some changes that we've not been able to overcome...yet. I've been able to get cameras to work, capture motion, view stills and export video but not view the stream.
Also, the Launchpad repository does not have the packages for ZM 1.26.4 which will install on Ubuntu 13.10. I have downloaded the packages for Ubuntu 12.04 and installed them on 13.10 with dpkg. It is messy and rather than confuse more folks I've not detailed it into a how to.
For now you are best staying with Ubuntu 12.04 and either the 1.25.0 or 1.26.4 installs. I'll try to keep both of those up to date as things, like Cambozola, change.
bb
digitel
Post by digitel »
Thank you for reply
Good to know this, so, as the 13.10 distro is not really necessary, i'll go with 12.04 until the whole thing will be ok for new distro
I'll let you know
Regards
digitel
Post by digitel »
12.04 Server works like a charm at first shot !
