ERR-zmwatch.pl [Can't get shared memory id '7a6d0002', 2: No such file or directory]
%configure \
--with-libarch=%{_lib} \
--with-mysql=%{_prefix} \
--with-webdir=%{_datadir}/%{name}/www \
--with-cgidir=%{_libexecdir}/%{name}/cgi-bin \
--with-webuser=%{zmuid} \
--with-webgroup=%{zmgid} \
--enable-mmap=yes \
--disable-debug \
$OPTS
[root@localhost ~]# cat /etc/sysctl.d/60-kernel-shm.conf
kernel.shmall = 2097152
kernel.shmmax = 268435456
[root@localhost ~]# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 262144
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages Limits --------
max queues system wide = 1723
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
[root@localhost ~]# ls -hal /dev/shm/
total 12M
drwxrwxrwt 2 root root 60 Nov 6 12:59 .
drwxr-xr-x 19 root root 3.4K Nov 6 12:58 ..
-rw------- 1 apache apache 12M Nov 6 12:59 zm.mmap.2
Is there a way to check if binary is compiled with mmap ? or
Do I need to recompile the .rpm myself to make sure they indeed did --enable-mmap=yes ?
The reason I wish to get rid of this message is that Zoneminder feels really slow (imho because of this). And also I want to up the resolution of camera.
If you need any other info, I will make sure everything is at your disposal.
OS: Fedora 18 i686
ZM: Zoneminder 1.25
Best regards,
Momcilo.
