In the past I have purchased some 8 chip pci video capture cards from camsecure website.
Now I have a very big problem and I don't understand if the problem is related to Debian 7 or to the card.
On startup I see this log:
Nov 8 08:33:58 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:33:59 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:00 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:01 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:02 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:03 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:04 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:05 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:06 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:07 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:08 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:09 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:10 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:11 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:12 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:13 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:14 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:15 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:16 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:17 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:18 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:19 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:20 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:21 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:22 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:23 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:24 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:25 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:26 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:27 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:28 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:29 debian01 udevd[433]: timeout: killing '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501]
Nov 8 08:34:30 debian01 udevd[433]: '/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00' [501] terminated by signal 9 (Killed)
root@debian01:/home/denis#
Some machines now don't complete the startup.
In some cases the machines have a very long startup time, in some else I see all 8 input (/dev/video0 - 7), in some else I see only a few, in some else none...
I know the only thing to do in to copy the bttv.conf file in /etc/modprobe.d.
I have sent more emails to camsecure but no reply, I have tryed to call but the number is not correct, by skype but nothing...
Now I'm desperate...
Have you got any suggestion?
Problem with Debian 7 and 8 input pci video capture card
www.denisgottardello.it
Videosurveillance and home automation!
http://www.denisgottardello.it/DomusBoss/DomusBoss.php
Re: Problem with Debian 7 and 8 input pci video capture card
Up!
ho lo stesso identico problema ...
same problem with same configuration ...
Non è un problema di Debian, è la scheda. Se osservi ha 2 segni sullo slot pci. COme si legge nel sito vuole una particolare alimentazione.
Is not a Debian problem. The problem is the pci card. If you look at the pci slot it requests a particolar power, as you can read in the vendor website.
