Only stream from camera when monitor open - Nodetect?
Posted: Fri Nov 08, 2013 1:29 pm
I have some cameras that are on 3G modems and I have limited data traffic so I would like to only record on external events (zmtrigger or forceAlarm url)
which works fine with "Nodect" but I see that ZM always stream from the camera, and I would like ZM to only start stream from the camera when i trigger event or when i open the monitor.
If I switch the mode to "None" for the camera i see that ZM stop stream from the camera but then i would need to switch this mode all the time and i would rather see that i can just open the montor to get live feed.
Is this possible?
Regards
index.php?view=request&request=alarm&id=1&command=forceAlarm
Is this possible?
Regards
