I wonder if this is possible: monitor and analize at high fps, record at low fps (1fps for example) and record at high fps on alarm.
What I was able to achieve is monitor and record at 1fps. Record on alarm at 25fps (using the options "Maximum FPS" and "Alarm Maximum FPS").
I have found some post where the author mentions he always records at high fps and then, once a day, he make videos of alarms and delete the rest. Is this the only way?
Thanks,
Norberto
monitor/analize/alarm at high fps, record at low fps?
Re: monitor/analize/alarm at high fps, record at low fps?
I don't know if this will help your problem, but did you realise that you can have two monitors with different settings, both using the same camera?nbensa wrote:Hello,
For example, set monitor-1a to your camera, with monitor and analyse at "high" FPS, in modetect mode, ONLY recording when there is an alarm.
Set monitor-1b to use the same camera hardware, in plain "record" mode, at "low" FPS, recording at low rate all the time.
Does that help?
yes I knew it. I just find that solution somewhat "unclean". I'd like to have only one stream.
I'll go with "two" cameras for now. Maybe what I really need is an external trigger (X10?).
Thanks!
Thanks!
