Monitoring Axis camera , red screen activates recording
digitel
Post by digitel »
Hi
I'm using an Axis 2100 camera on my one and only Monitor1 set as MODECT to record when motion is detected
I noted a lot of event recorded , mainly with no movement
However, playing back the recording I see a fraction of second of red screen (like no camera working) on each recording
Can this be the event triggering the recording ???
How to get rid of ???
I see some red screen flick also simply monitoring the camera in MONITOR only mode (live monitor)
Any hint on what to work about please ???
Re: Monitoring Axis camera , red screen activates recording
It's probably the camera, I don't think it's rated as one of their better efforts. You can change it or try to fiddle the config around the problem. You might manage to get it to ignore if it's just one frame. I've never tried that, but alarm frame count might be worth a look.
digitel
Post by digitel »
Yes, Axis 2100 isn't a great camera.....
"Alarm frame count" set to 4 or 5 solved the problem in some way.....
Thank you for hint
