Ubuntu 13.10
claytonasmith
Ubuntu 13.10
Post by claytonasmith »
I followed the instructions posted for the Ubuntu 13.10 zoneminder early fix, but I still get a blank page. Any ideas are welcome - and I'm happy to upload log files or VNC if necessary.
- I still get a blank page at localhost/zm
- I DO see a valid page at localhost
- I tried the following steps (from quick fix for Ubuntu 13.10)
ln -s /etc/zm/apache.conf /etc/apache2/conf-enabled/zoneminder.conf
sudo nano /etc/php5/php.ini #and change short_open_tag = Off to short_open_tag = On
/etc/init.d/apache2 force-reload
digitel
Re: Ubuntu 13.10
Post by digitel »
http://www.zoneminder.com/forums/viewto ... 30&t=21609
Admitting you will solve your (perhaps easy) issue, there will be bigger next....
I solved with 12.04 server installation
Hope this helps somewhat
claytonasmith
Re: Ubuntu 13.10
Ahh... Thank you very much... I will do the same.
Re: Ubuntu 13.10
Anyone still working on Ubuntu 13.10, I did a test. See:
http://www.zoneminder.com/forums/viewto ... 266#p82266
Need someone with Apache knowledge.
bb
