Zoneminder Foscam Red image
smot11
Post by smot11 »
Hey guys, Having issues with the newest version of zoneminder, after recently updating my network/ re-installing my server.
I'm using foscam FI8918W IP cameras, running a fresh install of ubuntu server 12.04 running zoneminder 1.26.4 and used THIS guide.
I'm using this as a guide to how to set up my camera.
With the basics of how I set this up out of the way;
I am getting the "red screen" error that a few users have being experiencing, with different error messages.
I cant attach the image - 3 image limit, and can't post external links due to being too spammy for a new user.
Zoneminder log
Zoneminder log
I checked if my camera has an active steam accessible via the intranet (yes)
Finally, I set log level to 5, and saved the logs
Log part 1
Log part 1
Log part 2
Log part 2
As far as I can tell;
The camera is able to connect, zoneminder is actively comparing the pixels from it (Second screenshot), yet i'm still getting the red screen error.
Can anyone suggest how I may approach fixing this issue?
smot11
Re: Zoneminder Foscam Red image
Post by smot11 »
(sorry for the double posting)
To bypass the three images per post;
Red capture screen via /usr/share/zoneminder/events
mastertheknife
Post by mastertheknife »
The errors you are receiving are because of a resolution mismatch. The camera's resolution is higher than the resolution you entered.
Kfir Itzhak.
smot11
Post by smot11 »
That worked, thankyou for your help. Out of curiosity, how were you able to work this out? Was it the "Buffer is undersized" error?
