Hi, thank you for zoneminder. I'm only just starting to use it but it seems awesome so far!
I have just set up a wanscam jw0011, a cheap outdoor IP camera. It worked first time once I followed the instructions here: http://www.zoneminder.com/wiki/index.ph ... rom_a_.deb
In particular, the stuff after the first paragraph!
There are two things worth confirming for the forums:
First, the video path for these is /videostream.cgi?user=[username]&pwd=[password]
(You can set up three levels of user for the camera through its configuration menu, so I set one up just for zoneminder viewing.)
Second, for what it's worth you can Telnet into these things: username is root and password is 123456
I really have nothing to compare it with: I've never owned a home surveillance camera before. The resolution is 640x480 and the picture is clear enough. Hope this helps someone.
wanscam jw0011
Return to “Hardware Compatibility List”
Jump to
- General
- ↳ Announcements
- ↳ Website Issues
- Support
- ↳ ZoneMinder 1.36.x
- ↳ ZoneMinder 1.34.x
- ↳ Mobile Apps and Event Server
- ↳ Docker
- ↳ ZoneMinder Distributions
- ↳ ZoneMinder Translations
- ↳ Archive [End of Life Versions]
- ↳ ZoneMinder 1.35.x Development Branch
- ↳ ZoneMinder 1.33.x Development Branch
- ↳ ZoneMinder 1.32.x
- ↳ ZoneMinder 1.31.x
- ↳ ZoneMinder 1.30.x
- ↳ ZoneMinder 1.29.x
- ↳ ZoneMinder 1.28.x
- ↳ ZoneMinder 1.27.x
- ↳ ZoneMinder 1.26.x
- ↳ ZoneMinder 1.25.x
- ↳ ZoneMinder 1.24.x
- ↳ ZoneMinder Previous Versions
- Development
- ↳ ZoneMinder 1.37.x Development Branch
- ↳ Feature Requests
- ↳ User Contributions
- Miscellaneous
- ↳ ZoneMinder Hints & Tips
- ↳ Non-ZoneMinder Chat
- ↳ Jobs / For Sale / Wanted / Exchange
- ↳ Hardware Compatibility List
- ↳ Hardware Queries
