Howto install mythZMserver after fresh install of Zoneminder
I installed Zoneminder from --> http://www.zoneminder.com/wiki/index.ph ... e_easy_way I have it running fine on Ubuntu 64bit 12.04.3 server. I have not been able to find how to install the mythzmserver components, so that it can be viewed through my MythTV installation. Linux novice, so all details and commands would be helpful. Can't find a package, etc with this, so I am not sure what files, etc are needed and how to install.
- knight-of-ni
Re: Howto install mythZMserver after fresh install of Zonemi
Well, I just added an entry into /etc/rc.local:
In either case, you should consult the mythtv website and read the documentation there:
http://www.mythtv.org/wiki/MythZoneMinder
# Launch mythzmserver
/usr/local/bin/mythzmserver -d
