Speco SIPD3
JohnnyDigital
Speco SIPD3
Post by JohnnyDigital »
The Speco SIPD3 (IP dome camera) is no longer made, however if anyone comes across an old one, they may be interested to know that they work fine with ZM.
Key camera settings to be aware of:
Video Display: MJPEG
HTTP Port: 80
Streaming Method: TCP Only
B2 Frame Enable: Off
Resolution: 640x480
Frame Rate Mode: Constant
Frame Rate: 15
Encoder Type: MJPEG
Key ZM (source) settings:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: admin:123456@192.x.y.z
Remote Host Port: 80
Remote Host Path: cgi-bin/cmd/system?GET_STREAM=VIDEO&USER=admin&PWD=123456
Capture Width (pixels): 640
Capture Height (pixels): 480
(Unfortunately, I've had only limited success with Speco's replacement model, O2D4. I'll post that in another thread.)
