I have two Foscam FI8910W IP Cameras and can view them remotely via my no-ip url and port number via Firefox or Chrome and the Foscam Application. I have ZM 1.25 installed and have configured one camera and show orange light for Function, Red Light for Source and appears to grey light for Name. I have several errors showing in my log file, but don't know how to resolve them.
I am using Linux Mint 15 with Cinnamon on a Dell Laptop. I have followed several Youtube Videos for installing Zoneminder, but can't get my live view to load. I am attaching my log file, if someone would like to review it.
Thanks in advance.
My apologies, if this is a duplicate message as I am having a problem with the uploading of my log file.
No Live View after Installation
- zm-log.txt.tar.gz
- Zoneminder Log file.
- (1.75 KiB) Downloaded 140 times
Re: No Live View after Installation
After doing some digging around here I found this:
If you are using the most recent version of Mint you will run into the same problems we have with Ubuntu 13.10. I recommend you go back to Mint 13 then use the How-To located at: http://www.zoneminder.com/wiki/index.ph ... 04_Desktop
Is there no hope for me on Linux Mint 15? Going back to Mint 13 is not an option for me.
Anybody????
check PM
me too!
On a bit of a whim I decided to install Fedora 20 on my zm server. My intention was to upgrade everything software. I installed zoneminder from rpms. So now I am at v1.25.0.
I had to add zmuser & pass manually and run the /usr/share/zoneminder/db/zm_create.sql
I can get the web interface up, but when I try and show the monitors there is no live view. Seems it has been a long time since I installed zm, because I can't even think where to dig.
I have cambozola-0.93-1.fc20.noarch installed.
I have java installed
# rpm -qa | grep java
python-javapackages-3.4.1-1.fc20.noarch
java-1.7.0-openjdk-headless-1.7.0.60-2.4.3.0.fc20.i686
tzdata-java-2013i-1.fc20.noarch
javapackages-tools-3.4.1-1.fc20.noarch
java-1.7.0-openjdk-1.7.0.60-2.4.3.0.fc20.i686
I can't find any useful errors.
I have this one ... but for some reason I feel like I've had it before and it can be ignored.
Corrupt JPEG data: 1 extraneous bytes before marker 0xd9
update
on fedora with rsyslog - you can make that annoying error go away by getting rsyslog to drop it:
I made a file /etc/rsyslog.d/jpeg.conf - with one line in
# cat /etc/rsyslog.d/jpeg.conf
:msg, contains, "extraneous bytes before marker" ~
I abandoned fedora 20 for zoneminder when I found that there is indeed am issue on Fedora 18 - I assume it lives on in Fedora 20
ffmpeg libraries from Fedora rpms do not work with zm. You have to install from source (yuck).
also I discovered that turning on web auth breaks video - this needs to be posted in huge letters all over
Apparently when you turn on OPT_USE_AUTH when using cambozola it breaks due to the Options ----> System ----> AUTH_RELAY not being set to "none" for whatever reason.
update
It appears that my problem on Linux Lite was that zoneminder was not running even though I could open up the GUI. I clicked on the Stopped link and it turned to Running. I am now able to view my one camera that is installed. I am having one issue and I'm not sure if this is a feature. Every 20-30 seconds the screen Live Video feed goes completely Blue for 1-2 seconds and then refreshes to the Live Image feed.
Is this normal or is there a setting that I need to modify to gid rid of this behavour? I have already modified my:
kernel.shmall = 268435456
kernel.shmmax = 268435456
Is there a command to automatically start zoneminder so I don't have to click on the link in the GUI?
Yes, depends on your particular system though.wussery wrote: Is there a command to automatically start zoneminder so I don't have to click on the link in the GUI?
On mine (Slackware), the file /etc/rc.d/rc.local starts up stuff that needs doing on boot. At the tail end ... I have ...
# Start ZoneMinder
# Get more shared memory
echo 20300000 > /proc/sys/kernel/shmmax
echo 34650 > /proc/sys/kernel/shmall
# Fix dropped packets with increased buffers, was 256
ethtool -G eth0 rx 1020
/usr/local/bin/zmpkg.pl start
/usr/local/bin/zmpkg.pl stop
