purgewhenfull not working
I had to reinstall my ZM system (still running on Fedora 14, because I had issues trying to get it running on Fedora 18). The PurgeWhenFull filter doesn't appear to run. I noticed that there's no "run in background" option (there was in the past). I'm now on 1.24.2. Am I missing something in this release? If I have the filter window open and manually execute it, it runs fine...but will not run in the background.
Re: purgewhenfull not working
Never mind....found it. Just for my own future reference (and in case it's helpful), you need to SAVE it, not just SUBMIT. When you save you get prompted for the option to run in background. It doesn't appear to run at all until you do this.
