No live monitor with ubuntu 13.10, socket_sendto err SOLVED
Posted: Sun Feb 02, 2014 7:51 am
Hello Zoneminder people! I hope someone can help with this, as I have spent days banging my head trying to get it to work. I'm using a Foscam wireless IP camera, FI8905W. I can access and configure it via its own Web admin interface. But I cannot get live monitoring in Zoneminder on Kubuntu 13.10. I have searched the Web and these forums and it seems a number of people have the same problem, but no fix. I'm starting to think it is a bug, because I was able to install Zoneminder and get up and running in ten minutes on an old Linux Mint 13 installation, including live monitoring. I followed the wiki pages at http://www.zoneminder.com/wiki/index.php/Foscam_FI8904W and http://www.zoneminder.com/wiki/index.ph ... e_easy_way, and it was easy. I don't even know where to start troubleshooting. The Zoneminder logs are clean.
A lot of people are plagued with the 'socket_sendto( tmp/zm/zms-.sock ) failed: No such file or
directory' error in their ZM logs. I fixed it on my system by changing gettimeofday() to
date_default_timezone_set() on line 412 of /usr/share/zoneminder/includes/logger.php
Any bright ideas on getting live monitoring to work on Kubuntu 13.10? Or even dim ones? Thank you!
