no link on "name" to bring up viewing window
DrKappy
Post by DrKappy »
Just finished setting up centos 6.5 with zm 1.26.5 using a kodicom 8800 (old pentium 2 system, but still works)
Configured the first camera and the source "/dev/video7 (0)" is red, selected "Mocord" which is green, but I try clicking on the name of the monitor (which I called "Front_Door"), there is no link to click on to bring up the window to view.
If I click on the Events and actually go to the jpeg events, I can see the individual pictures there.
Any guidance from this point is much appreciated.
Thanks - Kap
DrKappy
Re: no link on "name" to bring up viewing window
Post by DrKappy »
Also...
Seeing this in the logs...
Feb 17 14:14:33 surveillance zmc_dvideo7[1642]: INF [FD3: 70000 - Capturing at 29.41 fps]
Feb 17 14:14:37 surveillance zma_m2[1650]: INF [FD3: 70000 - Processing at 30.30 fps]
Feb 17 14:15:06 surveillance zmc_dvideo7[1642]: INF [FD3: 71000 - Capturing at 30.30 fps]
Feb 17 14:15:11 surveillance zma_m2[1650]: INF [FD3: 71000 - Processing at 29.41 fps]
Feb 17 14:15:40 surveillance zmc_dvideo7[1642]: INF [FD3: 72000 - Capturing at 29.41 fps]
Feb 17 14:15:44 surveillance zma_m2[1650]: INF [FD3: 72000 - Processing at 30.30 fps]
Feb 17 14:16:03 surveillance web_php[1372]: WAR [Adjusting to minimum width when getting popup size for tag 'event' - getPopupSize()]
Feb 17 14:16:03 surveillance web_php[1377]: WAR [Adjusting to minimum height when getting popup size for tag 'event' - getPopupSize()]
Feb 17 14:16:03 surveillance zms[1805]: INF [Authenticated user 'admin']
Feb 17 14:16:03 surveillance zms[1805]: FAT [Can't open memory map file /dev/shm/zm.mmap.2, probably not enough space free: Permission denied]
Feb 17 14:16:06 surveillance web_php[1371]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-185567s.sock ) failed: No such file or directory]
Feb 17 14:16:13 surveillance zmc_dvideo7[1642]: INF [FD3: 73000 - Capturing at 30.30 fps]
Feb 17 14:16:18 surveillance zma_m2[1650]: INF [FD3: 73000 - Processing at 29.41 fps]
Feb 17 14:16:46 surveillance zmc_dvideo7[1642]: INF [FD3: 74000 - Capturing at 30.30 fps]
Feb 17 14:16:51 surveillance zma_m2[1650]: INF [FD3: 74000 - Processing at 30.30 fps]
PacoLM
Post by PacoLM »
Well, this is a really self-explanatory error message: "FAT [Can't open memory map file /dev/shm/zm.mmap.2, probably not enough space free: Permission denied]"
