I recently installed my ZoneMinder 1.25 and upgraded to 1.26.5
I configured 2 IP cameras (Loftek) as Monitor but I am not able to see any Video Stream.
The error at /var/log/messages is:
Feb 20 18:57:42 zoneminder web_php[14002]: ERR [socket_sendto( /tmp/zm/zms-566998s.sock ) failed: No such file or directory]
Feb 20 18:57:42 zoneminder web_php[13801]: ERR [getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-566998s.sock ) failed: No such file or directory - checkStreamForErrors()]
Feb 20 18:57:42 zoneminder zmwatch[17652]: ERR [Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0]
Feb 20 18:57:42 zoneminder zmwatch[17652]: ERR [Memory map file '/dev/shm/zm.mmap.2' should have been 896 but was instead 0]
Feb 20 18:57:48 zoneminder web_php[14003]: ERR [socket_sendto( /tmp/zm/zms-566998s.sock ) failed: No such file or directory]
Feb 20 18:57:48 zoneminder web_php[14004]: ERR [getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-566998s.sock ) failed: No such file or directory - checkStreamForErrors()]
It is continuos.
I have installed ffmpeg version:
[root@zoneminder dev]# ffmpeg
FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers
built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6)
configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
libpostproc 51. 2. 0 / 51. 2. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
Thanks in advance for any idea.
Regards,
Bazcor
Socket error at v1.26.5
Re: Socket error at v1.26.5
I think this could be related to my issue as well..
http://www.zoneminder.com/forums/viewto ... 30&t=21946
but i have no solution.
